Pls Help-Check Engine Light
Old May 30, 2010 | 11:40 PM
Vette707's Avatar
Vette707
Default Pls Help-Check Engine Light
Took a nice ride tonight and everything was going well and all of a sudden the check engine light came on and stayed on. The care was running great and I made it home with no problem. Any idea what can be wrong ? Thanks for your help.
Old May 30, 2010 | 11:43 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
The first thing you need to do is pull the codes, On the C5 you can do it using the Drivers Info Center(DIC).
Here is a link on how to do that. And has a list of codes also. Look for codes that has a C after it, That will be current.
Mr.Bill
http://www.stengel.net/diccodes.htm
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES". Press OPTIONS to go to the next module. Repeat the steps in this paragraph until you have reset the codes in all the computer modules
. NOTE !! Only reset the codes IF you want to - it is NOT necessary to do this.
Old May 31, 2010 | 09:33 AM
Vette707's Avatar
Vette707
Tks Mr Bill. I will pull the codes today.
Old May 31, 2010 | 03:30 PM
Vette707's Avatar
Vette707
I checked codes and found a few H (history) codes but no C (current) codes. I started the car and the check engine light was Not on. Any idea what may be wrong ? Tks for your help.
Old May 31, 2010 | 03:34 PM
Chicago1's Avatar
Chicago1
What codes did you have?
Old May 31, 2010 | 03:35 PM
Mr.Bill's Avatar
Mr.Bill
Sometimes the Vette does some strange things, I would clear all codes and drive it, What are the H codes, It will tell you why you got the light.
Old May 31, 2010 | 07:01 PM
Vette707's Avatar
Vette707
The H (history) codes I found were 2282h, 2285h,2236h,2284h and 2283h. There was no C (currrent) codes listed. Any idea's ? Tks,
Old May 31, 2010 | 07:05 PM
Mr.Bill's Avatar
Mr.Bill
Hmm, They might be battery related, Have you had any battery issues?
dobewillie's Avatar
dobewillie
Good luck finding your problem as Bill stated some times these cars do funny things
Old May 31, 2010 | 07:12 PM
Mr.Bill's Avatar
Mr.Bill
B2282 Battery #1 Circuit
B2283 Battery #1 Circuit
B2284 Battery #2 Circuit
B2285 Battery #2 Circuit
B2236-B2239 Door Lock Switch Circuit
Old May 31, 2010 | 08:15 PM
Vette707's Avatar
Vette707
All the codes were H codes. I was told these are problems that were in the past (history) and have since been corrected. I was told to look for C codes which mean current problems. Is my info correct ?
Old May 31, 2010 | 08:17 PM
Vette707's Avatar
Vette707
The battery was just replaced last summer. I have not had any battery related issues.
Old May 31, 2010 | 10:11 PM
Mr.Bill's Avatar
Mr.Bill
Drive it and see if it happens again.
Old May 31, 2010 | 10:41 PM
2003 electronblue's Avatar
2003 electronblue
when mine went on it turned out to be a bit of carbon when into one of the valves...just clear the codes that should be all thats needed..
Old May 31, 2010 | 11:29 PM
8VETTE7's Avatar
8VETTE7
Clear all the codes. Drive the car for a bit then pull the codes again.
Could be a fluke but if there is a real problem it WILL be back. The codes will tell the story of what the BCM is not happy with.
To Pls Help-Check Engine Light
