Check engine light
Old May 30, 2010 | 11:49 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Default Check engine light
Check engine light came today.Should I be worried?
Old May 31, 2010 | 12:00 AM
AU Eagle's Avatar
AU Eagle
St. Jude Donor '08-'09-'10-'11, '14
Have you done anything recently with the car?
To find the codes
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
Old May 31, 2010 | 02:13 AM
dougbfresh's Avatar
dougbfresh
Your a Senior Member and you ask THIS?
Pull the codes and post them.
To Check engine light
