[Z06] Z06 Cooling
1st is a 10 degree differential normal. If it is normal than isn't that a big fuel economy issue?
2nd I thought the fans ran until the temp went down to whatever the thermostat is set for. What should the thermostat be set for?
You may (mentally) benefit by altering the fan(s) on/off settings if you're of the old school thinking that all cars must run at 160-180 degrees. The settings can be changed by a tuner.
If you use search or search this forum (in the red banner) in C5 Tech, use keywords "electric fan settings" or similar for lots of informative reading about the technology of a C5/Z06 cooling system.
The higher temperatures used to concern me during AZ summers. I don't watch the coolant temperatures as much as I do the oil temperatures. I scroll to oil temperatures on the DIC/gauges and leave it displayed instead of watching my odometer. Summer time ambient air and heat rising from the roadway contribute to the problem.
I find my temperatures creeping up if I'm stuck in lots of traffic or in a lower gear on a winding mountain road. My oil temperatures have gone as high as 252 degrees. Once the traffic clears or I can get into a higher gear, the temperatures come down quickly. That's exactly what one should expect. If you find your temperatures don't come down, inspect the front of the condenser and radiator for debris. Since these cars are bottom feeders, they're notorious for picking up junk from the roadway (plastic bags, leaves, etc) which block incoming air flow to the aluminum radiator. A routine inspection and careful cleaning will eliminate that as a problem. You can also buy or DIY a screen to keep the larger junk from blocking the radiator.
Hotwhels57 pretty much answered your questions but I'm just adding this as a suggestion, better fuel economy
My old school training (pre computer control) was that actual temperature is not as important as how much it varies. If it is normal to run at 210 that is fine but if the temp varies 10 degrees the engine loses about 5 to 10% fuel economy. I'm not sure of the computer and what it may be controling. I'm not looking to second guess the designers but trying to figure out if I should just ignore the variation and trust the design or do I have a problem that I need to look at.
