[Z06] traction control
Old Jun 3, 2010 | 12:05 AM
bikejunkie's Avatar
bikejunkie
Default traction control
If I drive with the Traction control on the second setting( allowing more wheel spin) will I get more acceleration???
Old Jun 3, 2010 | 01:35 PM
James92's Avatar
James92
As long as your tires have traction your acceleration will be the same in all modes.
Old Jun 4, 2010 | 07:02 PM
Bill Dearborn's Avatar
Bill Dearborn
The second setting is with traction control totally off. You may or may not get more acceleration depending on how hard you spin the wheels.
Old Jun 4, 2010 | 08:17 PM
johnnytaboo's Avatar
johnnytaboo
nailed it. Doesn't matter if the car has traction control on, off, or is in sport mode (or whatever it's called). The only thing sport and t/c off let you do is get a bit more wheel spin. Fun if you enjoy drifting.
Old Jun 4, 2010 | 08:36 PM
02EBZ06VA's Avatar
02EBZ06VA
So the traction control on these does not slow the car down or retard timing like on the F-bodys?
Old Jun 6, 2010 | 03:17 AM
philadd's Avatar
philadd
With everything on, the traction control system allows a pretty good amount of wheel sping in 1st gear before it decides to step in. Any more spin than that would probably just roast the tires. The traction control really steps in by 2nd gear though.
To traction control
