turn flasher
Old Jun 11, 2010 | 10:07 PM
Ja's_baby's Avatar
Ja's_baby
7th Gear
Default turn flasher
I have a 2000 Vette with weird signal behavior.....turn signals may or may not work when activated...same with emer flashers....have changed all bulbs....does it have, and if so where is, the flasher switch and how do I identify it??
thanks
Old Jun 11, 2010 | 10:17 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
It is your flasher relay, It is up behind the 4 way flasher switch, The best was to fix this is to get a LED Hyper Flash relay from JWMotoring a forum vendor, You can sometimes fix it for a bit by hitting the flasher switch on the dash fast about 10 times.
Mr.Bill
Old Jun 11, 2010 | 10:18 PM
8VETTE7's Avatar
8VETTE7
The flasher switch and the emergency flasher are one and the same switch. Switch is located behind the button you push to operate the hazard flashers. Can you say "some disassembly required"? Here is a link that explains the process in detail:
http://www.kd5fx.com/HSwitch/HSwitch.htm
Old Jun 11, 2010 | 10:30 PM
RSchleder's Avatar
RSchleder
Had the same problem with my 2000 vert 3-4 years ago. I installed the flasher bi-pass cable you can buy from several forum vendors and all is well 4 years later. $60 and 1/2 hour makes a it easy to choose the bi-pass cable!!
Old Jun 12, 2010 | 12:24 AM
01magnetic01's Avatar
01magnetic01
Old Jun 12, 2010 | 08:58 PM
Ja's_baby's Avatar
Ja's_baby
7th Gear
by "by-pass cable", what am I bypassing?? will I still have emer flashers and full function on turn signals?? thanks
Old Jun 12, 2010 | 10:06 PM
Mr.Bill's Avatar
Mr.Bill
Everything will work just like factory, The hew bypass flasher just plugs in under the dash on the drivers side, And if you go LED lights you will be set.
Old Sep 9, 2010 | 06:34 PM
FourG63 97GST's Avatar
FourG63 97GST
glad I found this link, I've been dreading pulling my dash to install a switch I had sitting in my truck. I just did mine, took like an hour
can't believe i've been beating on my dash for like a month whenever I had to turn
Old Sep 9, 2010 | 09:19 PM
vettman96's Avatar
vettman96
:QUOTE=RSchleder;1574369048]Had the same problem with my 2000 vert 3-4 years ago. I installed the flasher bi-pass cable you can buy from several forum vendors and all is well 4 years later. $60 and 1/2 hour makes a it easy to choose the bi-pass cable!![/QUOTE]
To turn flasher
