VIN covered on dash... help
Old Jun 12, 2010 | 12:40 AM
toofazt's Avatar
toofazt
Default VIN covered on dash... help
Hey guys, there's a couple tickets covering the VIN on my dash from the previous owner. They slipped down there and I can't figure a way to get them out without removing the entire dash. I've already tried a couple things but no luck. Any tricks or tips?
Thanks!
Old Jun 12, 2010 | 12:47 AM
LoneStarFRC's Avatar
LoneStarFRC
Short piece of stiff mechanics's wire. Bend a little "L" on the end. Coat hangar wire probably going to be too thick/big.
Old Jun 12, 2010 | 12:48 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Have you tried one of the flexible grabbers that are used to grab screws and such that fall into the engine area? They have a claw type end.
Similar to this.
Old Jun 12, 2010 | 12:51 AM
toofazt's Avatar
toofazt
I tried some wire but it was impossible to get any type of grip on the cards. All it would do is move them around a little.
Similar to this.
There's no way that would fit... I'd say there's maybe 1/8" gap.
There's a foam liner that makes it frustrating. Once you get one of the cards moving up, it hits the liner and drops back.
Thanks for the replies.
Old Jun 12, 2010 | 12:53 AM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try a small piece of double sided tape on the end of thin cardboard.
Old Jun 12, 2010 | 12:56 AM
toofazt's Avatar
toofazt
I tried tape and it just sticks to the dash or window before it gets to the cards. Maybe I can find some less sticky thin tape that will make it to the cards...
Old Jun 12, 2010 | 12:57 AM
Cozmo's Avatar
Cozmo
What about a dental pic with a sharp point? Maybe you could stick the point into the paper and pull it out.
Old Jun 12, 2010 | 01:00 AM
toofazt's Avatar
toofazt
I tried 4 different style dental picks but there's not enough room to hold it plus the shaft on them is too thick to get far.
LOL. I should of listed what I already tried in the first post, huh?
Old Jun 12, 2010 | 01:02 AM
Cozmo's Avatar
Cozmo
I'll sleep on it and check back here in the morning.
Old Jun 12, 2010 | 01:07 AM
olbear1962's Avatar
olbear1962
What about your shop vac with a blow nozzle to dislodge or use the narrow vacuum end.
Has worked for me in the past on other cars.
Old Jun 12, 2010 | 01:11 AM
Blue 92's Avatar
Blue 92
Double sided tape on thin cardboard, sticky tape side down and slide it down the glass.
Old Jun 12, 2010 | 01:27 AM
toofazt's Avatar
toofazt
I'll try both of these and report back tomorrow.
Thanks!
Old Jun 12, 2010 | 01:31 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I used an air hose and shot a few bursts and they came out.
Old Jun 12, 2010 | 01:35 AM
kennya35's Avatar
kennya35
I would think that would work.
Old Jun 12, 2010 | 01:41 AM
Choreo's Avatar
Choreo
I sort of doubt those "accidentally fell" into that area. Some people purposely "cover" their VIN number - this guy probably just did it in such a way that it would look like an accident. He may have done that with the dash out?
Old Jun 12, 2010 | 02:50 AM
LoneStarFRC
Maybe. I've got mine covered on purpose. Thin black plastic cut to a certain shape with a small "tab" with a hole in it that sticks up a little. I use a small piece of wire with a hook on the end to remove it if I need to for some reason, otherwise it stays covered.
Old Jun 12, 2010 | 07:11 AM
killain's Avatar
killain
Oldtimer
This is probably the best route to go at it, or using very thin machanic's wire with a shot of Upholstery adhesive on the end of the wire with a 'L' bend in it. Not sure, but I'm guessing here !
To VIN covered on dash... help
Old Jun 12, 2010 | 07:23 AM
rws.1's Avatar
rws.1
I used duct tape stuck to the end of a thin metal ruler (feeler gauge would work) the duct tape was stiff enough to stay off the dash until it got to where I want it....
Many cover theirs intentionally...
Using the VIN # any dealer can cut a key.... they are supposed to ask for ID and proof of ownership..... but ... there is always someone willing to turn a blind eye for a quick buck....
Old Jun 12, 2010 | 07:35 AM
Carcass's Avatar
Carcass
A small piece of 5% window tint material with a small tab on it for easy removal "fell" over mine about a year ago.
Old Jun 12, 2010 | 05:51 PM
hotwheels57's Avatar
hotwheels57
Vacuum cleaner with a narrow opening attachment?
