Weight diffrents
Old Jun 17, 2010 | 03:19 PM
XavierLT-4's Avatar
XavierLT-4
Default Weight diffrents
Wht is the weight diffrents between a Z06 or a FRC and a standard coupe?
Old Jun 17, 2010 | 03:37 PM
SCM_Crash's Avatar
SCM_Crash
Likely around 80Lbs. My friend's Vert was 3130. The Verts and FRCs weigh about the same with the FRC probably being just a tad heavier. Both my Z06s were with 10Lbs of each other and the lightest was 3070.
Old Jun 17, 2010 | 11:28 PM
XavierLT-4's Avatar
XavierLT-4
Thanks SCM Crash.For some reason I thought there was a big diffrence.
Old Jun 18, 2010 | 02:39 AM
SCM_Crash's Avatar
SCM_Crash
There's a much bigger difference between the coupe and the Z06, but the FRC was already lightened up by the lack of a large hatch window in the back.
Old Jun 18, 2010 | 04:31 AM
Curb weights:
Coupe - 3246 lbs
Z06 - 3116 lbs
Vert - 3207 lbs
These numbers were taken from the Corvette Black Book for various model year C5s. Seems like the weights varied a little bit between the years.
Old Jun 18, 2010 | 07:54 AM
AU N EGL's Avatar
AU N EGL
Curb weights:
Coupe - 3246 lbs
Z06 - 3116 lbs
Vert - 3207 lbs
Think the coupe and FRC is more then 80 lb diff, the coupe rear glass is 80 lbs by itself.
Darn close. But then again How much does the driver weigh?
Old Jun 18, 2010 | 08:02 AM
fastsuv's Avatar
fastsuv
Default Weight diff
The FRC was
Curb weight 3120 lb
Old Jun 18, 2010 | 08:58 AM
Blow Torch's Avatar
Blow Torch
Curb weights:
Coupe - 3246 lbs
Z06 - 3116 lbs
Vert - 3207 lbs
I though the vert was heavier than low 3100s. It has extra structural pieces added.
Old Jun 18, 2010 | 02:23 PM
SCM_Crash's Avatar
SCM_Crash
Nope. Weighed my friends 2000 Vert. It was 3130 with 1/2 tank of gas +/- 5Lbs (truck scale)
I know the scale is accurate because I weigh 150Lbs and stood on the scale and it showed 150Lbs. My friends also weighed themselves and it was accurate.
My first Z06 was 3080Lbs with 1/2 tank but it had HRE wheels. My current Z06 was totally stock other than the Vararam when we weighed it and it was 3070.
We don't have any stock coupes to weigh yet, but when we weighed my friends 98 with an A&A blower, it was 3320.
All of our cars are 6-speeds which is lighter than the autos. ALL FRC cars came with 6-speeds as well. So if you're comparing the FRC to a coupe, you need to take into consideration whether it's an auto or a manual.
To Weight diffrents
