Help needed Factory paint code U855 ??????
Jun 18, 2010 | 10:00 AM
My friend just bought a 2001 vert with a Factory paint code U8555 . G.M. does not list this color even as an option. The color is Onyx Black. Is this a rare color or did G.M. use this as a Test Mule.
Any info on this would be a great help.
Thanks, C5-JIM
Jun 18, 2010 | 10:05 AM
2018 C5 of Year Finalist
Did you enter the 3rd "5" in your search? (U8555)
Jun 18, 2010 | 10:56 AM
The paint code for black is 41U. Since you didn't print the whole label, I think it's the last number on the lower right in your picture.
Jun 18, 2010 | 02:16 PM
Quote:
Originally Posted by
MSG C5
Thanks, C5-JIM
Jun 18, 2010 | 02:20 PM
Torchblue
The whole paint code is in the picture and it is not 41u.
The clear coat and base code is u8555.
Thanks, C5-JIM
Jun 18, 2010 | 02:24 PM
Jun 18, 2010 | 07:55 PM
St. Jude Donor '05-'06
It's been some time now,but I believe my 98 had that same paint code(black).I am almost positive,so it was likey correct for that particular year.
Jun 18, 2010 | 08:18 PM
2017 C3 of Year Finalist
flynbya2
41 was the code in 98, but not 01. i don't know how to read those sheets, so i don't have much to add to this...
Jun 19, 2010 | 01:18 AM
tdogg21
You are correct, but wrong at the same time. That is not the code they use ,or at least used on the build sheet. They used the "WA" code,which is interchangeable with the "U"code,and is 8555. It is the same as my 98 was. I had to take that code to get paint to paint my spoiler.They used the same color/code black for all years 97-04
Check the link below....
http://www.corvetteactioncenter.com/...int_codes.html
Jun 19, 2010 | 01:26 AM
St. Jude Donor '10
The Corvette Black Book lists the color as "Black". They made 2702 verts in this color, second only to the 2781 Torch Red verts.
Since 1985, Black on Corvettes shows a code of 41, however U8555 appears to be synonymous with the 41 code on everything from Camaros to Chevy trucks.
Jun 19, 2010 | 01:34 AM
flynbyu2
As per the link above,you are correct.
P.S. just flew by ya
Jun 19, 2010 | 01:40 AM
St. Jude Donor '10
Hmmm, that 9th digit doesn't work with the VIN information I have. My info says it should be a "9" in there.
Strange...
Jun 19, 2010 | 09:46 AM
flynbyu2
Strange...
The 9th digit is a check digit used to determine the validity of the entire 17 digit VIN number; it can be either a numeric or alpha character.
I tried the VIN on a number of different sites and the numeric 0 as the checksum does show a valid VIN with the car being a 2001 Corvette convertible.
1999 ,
2004 ,
black ,
code ,
color ,
corvette ,
factory ,
find ,
gm ,
onyx ,
paint ,
red ,
rpo ,
u855 ,
u8555
