splash guards
Old Jun 20, 2010 | 09:44 AM
hattitude's Avatar
hattitude
Originally Posted by O4-/-C5
I just purchased front and rear Splash Guards from Lewis Five Motorsports.
I am extreamly happy with them.
Originally Posted by bowtiebubba
I have been looking at these. Did they fit right out of the box? No cutting or grinding to get them to fit?
Old Jun 20, 2010 | 05:01 PM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
Originally Posted by Mike98SilVert
thanks!
Old Jun 20, 2010 | 05:02 PM
tdogg21's Avatar
tdogg21
Originally Posted by TheRadioFlyer
Base C6 guards work as well. Not as effective, but less expensive and subtle. Fronts will be a direct fit, rears will require minimal shaving.
To get them to sit flush, I used black-painted stainless screws since the mounting tape included just wasn't doing the job.
Fronts:
Rears
so are you saying the C6 fronts fit with no modification? did you have to drill more holes for them?
Old Jun 20, 2010 | 05:03 PM
tdogg21's Avatar
tdogg21
Originally Posted by Jesse Asis
WCC has the C6 type for the C5, for $159, I'm going for them. I installed C6 Z06 Rims and went with the 1" wider front and rear. Tires come up right to the edge of the fender, so I kick up stuff right to the outside... My only concern is there is some adjustment, I'm not sure if that means using a dremel tool to trim the guards as if I'm installing actual C6 splash guards.... will call and get confirmation.
post here or PM me when you get an answer.
Old Jun 20, 2010 | 06:29 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The C6 fronts fit the front of the C5 with no trimming. You will still have to drill holes to mount them though.
Old Jun 20, 2010 | 10:14 PM
O4-/-C5's Avatar
O4-/-C5
No cutting,no grinding,no sanding - no nothing.They fit to near perfection from the get go.
In the way of a little back round:
I researched all of the Splash Guards that I could find and was not satisfied with what I found.To some degree this is due to my very fussy nature when it comes to my Corvette.
I heard about Lewis Five Motorsports from a forum member and found there facility was less than one hour from where I live.
I contacted them and set up a visit to see what there Splash Guards looked like. What I found was that they had a C5 dedicated as a proto type car for the design of there products.The Splash Guards were on this car for me to see form and fit. They then removed them from their car and held them up against my car to see what they looked like.
In detail conversation I found that these Splash Guards are made in a mold and are hand laid fiberglass. Interesting also is that they use black resin in the prosess so rock chips are not noticable over time.
They are finely designed and are not very obtrusive on the fender.
I ordered front and rear on the spot.
When I came back to pick them up they were on a table waiting. They were installed from the table to the car with no modification to the Splash Guards at all.
Based on my experiance this is a great product from good people.
Old Jun 20, 2010 | 10:21 PM
corvettedaddy11's Avatar
corvettedaddy11
C6 guards look better !!
Old Jun 21, 2010 | 03:51 AM
Trigger Creep's Avatar
Trigger Creep
I Forget
I hate 'em. I hate they way they look and when I drag them on a speed bump. yes, I do have the ugly things and need them. I like the Apsis design and will mod them with a bit of rubber on the bottom.
Old Jun 21, 2010 | 07:15 AM
99MALLETT396's Avatar
99MALLETT396
You have any pics?
Old Jun 21, 2010 | 09:22 AM
O4-/-C5's Avatar
O4-/-C5
Originally Posted by 99MALLETT396
You have any pics?
I have not taken pictures yet.
Old Jun 21, 2010 | 11:01 AM
tdogg21's Avatar
tdogg21
did you have to drill any holes? or did they use existing holes and double sided tape?
Old Jun 21, 2010 | 01:06 PM
O4-/-C5's Avatar
O4-/-C5
The front set used the two existing fender liner screw locations with new black screws provided. One small hole needed to be drilled on the underside and screwed into place with a black provided screw.
The rear set required drilling two holes,one into the fender fiberglass edge and one into the rear bumper edge and screwed into place with black provided screws. And again one small hole is drilled on the underside and screwed into place with a black provided screw.
Both front and rear sets has 3M double sided tape the full length of each guard on the inside which cannot be seen from the outside.
Old Jun 22, 2010 | 03:19 AM
  #33
bowtiebubba's Avatar
bowtiebubba
I think i am going to get a set of these.
Old Jun 22, 2010 | 09:09 AM
  #34
O4-/-C5's Avatar
O4-/-C5
Lewis Five took a lot of pictures of the installed splash guards on my car. They are not yet on there web site but they may be able to email them to you.
Mention Bobs Mgnetic Red vert and I am sure they will remember the insallation.
