[Z06] Trick Flow 220 Results
Old Jun 19, 2010 | 10:22 PM
mariofromnewyork's Avatar
mariofromnewyork
Late Model Domestics
Default Trick Flow 220 Results
2003 Z06
Blackwing
Vararam powerduct
LS2 Throttle Body
Fast 102mm
Fast Fuel Rails w/ custom lines
Yella Terra 1.7 RR
TFS 220 59cc
Va Speed Custom Cam 230ish 600ish 113ish
Fly cut pistons
ARH 1/34 & ARH Catted X
Ti's
Centerforce DF
42lb injectors
10% Underdriven
Bilsteins Sports
C6 Z51 Sways
Toyo RA'1 + sized and they hold hold and hold some more!!!
C6 ZO6 seats
kirban Shifter
I will post a dyno graph later as the printer was broke.
The car made 482 RWHP & 430ish RWTQ.
Before the stock 243's put down 431 RWHP & 398 RWTQ.
VA Speed, Brian in particular blended the bowl and touched up some other stuff on the 220's. I am very pleased with the results!
Ed did a fantastic job on the tune in the short time he had it.(I'm very impatient!)
Driving home I was on stock tires and it was all over the place just wouldn't hold the power. I put the Toyo's on and it is like glue.
Love It and thanks VA Speed! Very Happy!
Mario
Old Jun 20, 2010 | 12:41 AM
thechosenone's Avatar
thechosenone
Nice hp you got with those!
Old Jun 20, 2010 | 02:56 PM
QUIKSILVERZ's Avatar
QUIKSILVERZ
congrats!
was the 102mm fast ported?
Old Jun 20, 2010 | 07:34 PM
mariofromnewyork
Originally Posted by QUIKSILVERZ
congrats!
Fast was not touched and the LS2 Tb was polished up a bit!
Mario
Old Jun 20, 2010 | 11:56 PM
QUIKSILVERZ
very nice combo and numbers. congrats again
Old Jun 21, 2010 | 08:35 AM
Nysbadmk8's Avatar
Nysbadmk8
Very nice numbers..
Old Jun 21, 2010 | 08:57 AM
sami85L98's Avatar
sami85L98
Are these non CNc version TFS 220? and than ported or polish by VA speed?. Numbers are great. Congrarts.
Old Jun 21, 2010 | 09:26 AM
BillY2KFRC's Avatar
BillY2KFRC
Sounds like an awesome combo, fairly similar to my setup except my heads are AFR 205s. HP number is close to mine (I'm at 471rwhp, 409rwtq), but those Trickflows are making sick TQ, 430 is great for a stock cube setup. Enjoy it!
Are you planning to do gears? 3.90s really woke my car up and improved drivability.
Old Jun 21, 2010 | 05:11 PM
mariofromnewyork
TFS 220 as cast ported by Brian @ VA speed!
When the differential goes yes and the same for the Transmission!
Mario
Old Jun 23, 2010 | 11:22 PM
PRE-Z06's Avatar
PRE-Z06
nice numbers, were the gains just from the heads?
Old Jun 24, 2010 | 05:01 PM
Tropic Thunder's Avatar
Tropic Thunder
To Trick Flow 220 Results
