LS1 weak #7 cylinder
Old Jun 22, 2010 | 01:42 PM
futuretech's Avatar
futuretech
Default LS1 weak #7 cylinder
I have heard that the LS1's have a weak cylinder #7 (mine included). What about the LS6's? They have same block. Are they vulnerable too?
Old Jun 22, 2010 | 05:06 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
not sure what would make it weak. This would be a great question for the tech section, engine internals are they're thing.
Old Jun 22, 2010 | 05:17 PM
futuretech's Avatar
futuretech
Thanks. I usually ask the wider audience in this forum. I fugure the tech guys cross over. The number 7 cylinder has a reputaton for ring/piston failure (according to what I have read). It appears to the be the first point of failure. I am just trying to understand why (if it is in fact true).
Old Jun 22, 2010 | 05:22 PM
da_vato's Avatar
da_vato
I have actually heard this about all LS platform engines. Im curious to know about this and what the actual week point is.
Old Jun 22, 2010 | 05:32 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I"m thinking we should do away with "lucky 7" and just call it 9-2.
Old Jun 22, 2010 | 05:34 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The #7 cylinder is actualy the gets the leanest condition, it has been known to get piston slap and blow the rings in Boosted applications.
It is always best to tune a vehicle with a wideband O2 sensor closest to the #7 cylinder before the catalytic converter and right after the header collector. This gives you the best overall AFR readings and if it is good on the readings then the rest is going to be healthy too!
When you buy fuel injectors (flow matched inj's) it is always best to put the one with the slightly more flow in the #7 and #8 cylinders. When they go lean(more air than fuel), the cylinder detonates and can blow the ring or make it pin/Knock around in the bore.
This happened to mine under Boost, the cold winter morning offered more than the #7 could handle and I lost my ring - If you forge the motor parts - rings, rods, pistons etc - then tune accordingly you'll have a motor that last quite a long time and ys you can do it with a stock motor too!
Thanks,Matt
Old Jun 22, 2010 | 05:46 PM
Dominic Toretto's Avatar
Dominic Toretto
First time I have heard about this.
-Alex
Old Jun 22, 2010 | 06:03 PM
madmatt9471
-Alex
#7 is the furthest away from the air intake and can be starved for air, if not properly tuned it can lead to failure.
This pretty much goes for all motors with the cylinder furthest away - it's not like people are driving around and the #7 ring falls out
But when you mod, like H/C, LT's,Supercharger etc it is wise to make sure there is proper fueling etc.
Thanks,Matt
Old Jun 22, 2010 | 06:29 PM
AU N EGL's Avatar
AU N EGL
#7 also has slightly less coolant flowing around that part of the block in the LS6. These coolant gallies were corrected or slightly enlarged in the LS2 block
To LS1 weak #7 cylinder
