Question for lowered Vettes
Old Jun 24, 2010 | 12:48 AM
BOHICA76's Avatar
BOHICA76
Default Question for lowered Vettes
Do you remove the front spoilers and air scoop? I would think that the air scoop would scrape on everything. I am planning on getting the Fat Mammas to help with scraping.
Old Jun 24, 2010 | 01:11 AM
bumble-z's Avatar
bumble-z
Smart move on the Ma Ma's. Next smart move would be Rocker Savers. The 3 pc air dams are not to worry about. Yes they will rub and wear down from coming in contact with the concrete,etc on steep grades, speedbumps, etc.
Old Jun 24, 2010 | 01:19 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Old Jun 24, 2010 | 06:42 AM
4SFED Z's Avatar
4SFED Z
Scraping the air dam just means...go slower
Old Jun 24, 2010 | 07:23 AM
CurbsEnthusiasm's Avatar
CurbsEnthusiasm
Yup...you should see me with speed bumps and sewers.
Old Jun 24, 2010 | 07:51 AM
tdogg21's Avatar
tdogg21
2017 C3 of Year Finalist
that's why i haven't lowered mine. i like the look, but i drive the car too darn much to want to deal with the scraping.
Old Jun 24, 2010 | 08:29 AM
roscoe118's Avatar
roscoe118
If you are referring to the black 3 pc. "air dam" under the front of the car, DO NOT remove it! This is an integral part of the cooling system of the C5 since it is a "bottom feeder".
The middle piece is spring loaded so that it won't get too damaged when you do scrape, or hit a parking curb. It will, or may, get scraped up if you lower your car, but is inexpensive to replace if necessary.
I have read, here, where folks have shortened them, which should be fine if they are shortened by the same amount that the car is lowered.
Old Jun 24, 2010 | 08:31 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Yes.....
You will overheat if you remove the center air dam. Its what directs air into the radiator.
Toque
Old Jun 24, 2010 | 08:32 AM
81c3's Avatar
81c3
+1 Dont remove the air dam!
Old Jun 24, 2010 | 08:38 AM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
WHAT IS FAT MAMMAS? And where can you purchase?
Old Jun 24, 2010 | 08:51 AM
bumble-z's Avatar
bumble-z
CCA. "Custom Corvette Assessories". You will see their add to the left on this page. Once your on their site you will see pictures of the unit & pricing. It is a as set of double wheels to install & it protects the bottom nose from serious damage.
Old Jun 24, 2010 | 08:52 AM
jrose7004's Avatar
jrose7004
The air dam is self leveling over time.
Old Jun 24, 2010 | 10:16 AM
corvettedaddy11's Avatar
corvettedaddy11
Low is the way to go!!!
Old Jun 24, 2010 | 10:49 AM
Bandicoot's Avatar
Bandicoot
we have a set of bumper savers on order but for us the damage is done, the paint is scuffed below the pint of the nose. will have to replace and paint the front nose at some point.
Old Jun 24, 2010 | 11:04 AM
Superbock's Avatar
Superbock
I have almost 600 HP and I lowerd the car and took them off added rocker savers and I never over heat even with the AC on in 90 degree temps cruzing slow at the beach. The SC kit does change the angle of the rad I think so that may make a difference, I'm not sure. I left them on at first but they made a racket "all" the time
Old Jun 24, 2010 | 11:11 AM
bumble-z's Avatar
bumble-z
Thats why it is best to think things through before doing mods.
Going to lower car? #1 Do research from previous posts. #2. Buy your parts. Front & rear bolts. Front frame savers. Side rocker savers. #3 Lower front first, then the rear. #4 Adjust /Readjust ride height to your likeing. #5. If your like me, remove adjusters,front/rear springs & go w/coil overs. #6. Realizing after the fact that I should have done that from the beginning. But hey, I'm from the "show me state". LOL!!
Old Jun 24, 2010 | 11:54 AM
tdogg21's Avatar
tdogg21
me too. but i bought the car that way. i'm ok with it since i drive the car a good bit and i don't have to worry about scuffing a nice bumper, but i still wish it looked better.
To Question for lowered Vettes
Old Jun 24, 2010 | 06:07 PM
vette1017's Avatar
vette1017
I lowered mine and yes it does scrape from time to time but I love the look and don't regret doing it!
Old Jun 24, 2010 | 09:34 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Do Not Remove the air dams - theses assist our Vettes at hi-speeds!
Get the rollers up front and you'll be set
Thanks,Matt
Old Jun 24, 2010 | 10:31 PM
BOHICA76's Avatar
BOHICA76
That's what I would do too but they cost too much money.
