New? GPS mounting solution
Old Jun 24, 2010 | 04:47 PM
jrprich's Avatar
jrprich
Default New? GPS mounting solution
I ran across just the GPS mount I have been looking for on ebay and it only cost $6.
See what you think
Old Jun 25, 2010 | 01:02 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
^ gotta an item #
Old Jun 25, 2010 | 02:07 PM
jrprich's Avatar
jrprich
Originally Posted by ajg1915
^ gotta an item #
Here you go: Item number: 110481673767
But he has tons of these listed.
Also, ships from Hong Kong, so it takes a week or two.................
Old Jun 25, 2010 | 02:45 PM
v1 rot8's Avatar
v1 rot8
Default garmin
Did it come as pictured? The plate, ball sockets, etc?
Old Jun 25, 2010 | 05:41 PM
BigTattooMan's Avatar
BigTattooMan
St. Jude Donor '10
How is the reception when covered by the roof?
Old Jun 25, 2010 | 06:17 PM
jrprich's Avatar
jrprich
The mount is three pieces, plate, ball, and the adjustment nut. The garmin plate is not included.
Old Jun 25, 2010 | 06:18 PM
jrprich's Avatar
jrprich
Seems fine in my coupe
So far I have only used it with my painted top, haven't tried the clear top yet.
I plan to put another identical mount on my clear top.
I will route my Garmin power cable up the passenger pillar and along/under the vinyl trip at the top of the windshield. Should work fine.
Old Jun 25, 2010 | 07:23 PM
BigTattooMan
St. Jude Donor '10
Old Jun 25, 2010 | 08:59 PM
Blew by you's Avatar
Blew by you
I put mine in the vents, much nicer! it's in your line of site you don't have to look up, if your GPS falls on you while your driving it could be bad!?
Old Jun 25, 2010 | 09:15 PM
jrprich's Avatar
jrprich
To each their own.
I have used the vent mounting, but I do not want my vents blocked and in the roof position I use it is just a glance up past the rear view mirror.
Besides I rarely find myself looking at the GPS as much as listening to it's direction. Everyone has their own preference and at present I like this position in my C5.
Old Jun 26, 2010 | 11:59 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old Jun 26, 2010 | 12:10 PM
v1 rot8's Avatar
v1 rot8
Default as
Thanks for the info, I ordered one today.
Old Jun 26, 2010 | 01:32 PM
corvettedaddy11's Avatar
corvettedaddy11
Old Jun 26, 2010 | 08:50 PM
jrprich's Avatar
jrprich
Hope it works out for you.
I suggest you leave the GPS off the freshly stuck mount for a day to let the adhesive set up well. Also suggest you try the GPS in battery mode before you wire it in to make sure it receives well and you like it in that location.
Old Jun 26, 2010 | 09:08 PM
v1 rot8's Avatar
v1 rot8
Great idea, I will do that. Thanks
Old Jun 28, 2010 | 05:34 PM
jrprich's Avatar
jrprich
Yesterday I tested my wife's Garmin nuvi 650 as well. This model has the flip up antenna in the back. It fit fine and worked fine over a day trip.
To New? GPS mounting solution
