Problems with hideaway headlights
Old Jun 25, 2010 | 06:19 PM
tfrankmt's Avatar
tfrankmt
Default Problems with hideaway headlights
Recently my C-5 has developed a hideaway headlight problem.
When the headlights close the electric motor the closes them can be still heard running for at least 3 seconds after the lights are fully closed.
You can also hear what sounds like the plastic gears grinding as well.
It is very loud. Anybody else had this problem?
Todd
Old Jun 25, 2010 | 06:23 PM
japc5's Avatar
japc5
Common problem your plastic gears need to be replaced.
Here is a DYI on how to fix it.
http://forums.corvetteforum.com/c5-g...placement.html
and where to get the parts: http://rodneydickman.com/corvette.html
Old Jun 25, 2010 | 09:09 PM
Replace the plastic gears with the brass ones and you should be good to go.
Old Jun 25, 2010 | 10:07 PM
3BVert's Avatar
3BVert
Been there, done that. It's an easy fix. I have a spare brass gear waiting for when the other side strips.
To Problems with hideaway headlights
