Water Pump Replacement
Old Jun 26, 2010 | 01:02 AM
moserbe's Avatar
moserbe
Default Water Pump Replacement
Lost the water pump 10 miles from home tonight. Searched for Pump replacement but couldn't find it. Can anyone help?
Old Jun 26, 2010 | 01:15 AM
YNOT2K's Avatar
YNOT2K
this thread might help. g/l with the r&r.
http://forums.corvetteforum.com/c5-t...to-change.html
jeff
Old Jun 26, 2010 | 03:00 AM
LoneStarFRC's Avatar
LoneStarFRC
If you still have your original LS1 pump, go back with the LS2 or LS3 pump. Direct bolt-up and a better pump impeller design internally. You will have to also buy a thermostat housing and new thermostat too since these later engines don't use the old style LS1 housing/thermostat assembly.
HTH
Old Jun 26, 2010 | 10:11 PM
robsc501's Avatar
robsc501
Hi There,
Do a google search type in: water pump for 98 corvette on ebay. Click on the w/pump picture.Brand new GM water pump $225 + $15.00 shipping. Ships from St. Louis
robsc501
Old Jun 26, 2010 | 10:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here you go:
http://www.lmperformance.com/53406/4.html
http://www.rmsautoparts.com/proddetail.php?prod=251-722
How to replace it, principle is the same as the EWP:
http://www.ls1howto.com/index.php?article=26
Thanks,Matt
To Water Pump Replacement
