Question about recharging AC
Old Jun 26, 2010 | 08:12 PM
DansVette's Avatar
DansVette
Default Question about recharging AC
Which is the low pressure valve ? The one closest to the radiator, or the firewall ?
Old Jun 26, 2010 | 08:31 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
this will help
http://trans5.com/docs/C5%20AC%20Com...eplacement.pdf
Old Jun 26, 2010 | 09:05 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Originally Posted by pewter99
Nice write up but it doesn't show where the low pressure valve is located.
However since it does show the high pressure side I'm willing to bet the low pressure side must be the other service port.
Old Jun 26, 2010 | 09:59 PM
dougbfresh's Avatar
dougbfresh
Generally the 2 ports are different size fittings, the recharge kits will ONLY plug into the low pressure side. You should get a cheap set of guages anyway so you know what the high and low pressures are before you begin.
To Question about recharging AC
