Flashing km/h light
Old Jun 27, 2010 | 11:14 AM
rhubarb74roadster's Avatar
rhubarb74roadster
Default Flashing km/h light
The MPH-km/h light on my cluster has started flashing. It is not consistent. It will flash a few times, then stay off for a few seconds. It seems like it is trying to give me a code of some sort.
Pressing the button that switches the readings works, but the light itself does not change .. both MPH and km/h stay lit and flash together.
Any ideas?
Old Jun 27, 2010 | 11:34 AM
Phanni's Avatar
Phanni
Just a guess, but I'd check the grounding for the dash.
Old Jun 27, 2010 | 11:52 AM
Patman's Avatar
Patman
Does it do it while you are driving or while you are just sitting? I notice mine does this as well, but it does it when you're driving under bridges and areas where your car goes from a bright light area to a shaded area. I've always attributed it to the dash lighting reacting under different lighting conditions.
To Flashing km/h light
