How to fix, or replace this.
Jun 27, 2010 | 10:59 PM
Jun 27, 2010 | 11:03 PM
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
The base is still inside the socket? If so I've had luck using needle nose pliers to remove a broken base.
Jun 27, 2010 | 11:07 PM
No, I got the full Light out, whats circled is wahts broke, it holds the light in the turnsignal houseing
Jun 27, 2010 | 11:10 PM
You will have to order an new connector and then cut of the old one and splice on the new one. won't be hard.
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You might try NAPA for a new plug.
Jun 27, 2010 | 11:31 PM
Jun 27, 2010 | 11:49 PM
Quote:
Originally Posted by
2vettes2go
easy fix
Jun 28, 2010 | 12:02 AM
rudolph schenker
easy fix
Jun 28, 2010 | 12:43 AM
I have the same problem. GMPartsHouse only shows a replacement harness for $93. It doesn't appear that there is a pigtail available for that harness.
You might try salvage or PM somebody on here who is parting out a car.
Jun 28, 2010 | 02:54 AM
autozone sells them for atound $10 bucks,
I replaced one a few weeks ago.
all you do is cut the old wire and splice the new one in.
at my local store they are back next to the bulbs where they have a big section of sockets and other connectors.
Jun 28, 2010 | 06:56 AM
2vettes2go
An auto parts store may have a replacement at a cheaper price than a dealer.
Jun 28, 2010 | 03:36 PM
Oh hey I'm finding pigtails all over the place.
It should be 3-wire, not 2. Looks like it's GM part # 12003759. <<<--- THIS IS NOT THE RIGHT PART NUMBER
Rockauto has them for $4, Autozone says they are special order.
EDIT:
The one I ordered from Rockauto was wrong. Apparently this was for the rear. I went to an AC Delco store today and they did not show any Dorman parts for the bulb socket. Only the Delco, which was $40 or so.
Jun 28, 2010 | 04:13 PM
St. Jude Donor '09 thru '26
rudolph schenker
easy fix
yup it's an easy job.
Jun 28, 2010 | 04:51 PM
Use half a potatoe. I'm far from kidding. Make sure you push it on hard. Usually works for busted bulbs in the house, Get small one though. Obviously a fresh one.
Jun 28, 2010 | 05:48 PM
Lothar34
try advance or orilleys
Jun 28, 2010 | 06:49 PM
Jeffwilson34
I already ordered it from Rockauto. I needed some speedbleeders and they had them so I just ordered it with those.
Jun 28, 2010 | 06:57 PM
St. Jude Donor '09, '13, '15
Hot glue and some duct tape
