From: Obama says I'm a bitter white guy clinging to my guns and religon and he's right
There are 2 ways to install them. The quickest way is to install them is a followed:
Your turn signal lights are spring loaded and thus at the top of the turn signal light up can push in inward. While your pushing inward you can simply install the black out and position it where it will seat into position. If your black out kit is plexi glass it will bend a little. Be careful, it will break. This is how I installed mine and I had no issues. The other way to install them is to place the car on ramps and unscrew @ 6 to 8 bolts inorder to remove the housing and then install the kit.
I know a lot of guys hate the static cling black outs because they fall off. I has them on my 92 Ruby for two years and the 99 for almost a year, They never fell off. The key to success is be sure to clean off the lenses with alcohol to be sure there is no wax on the glass. If they come loose, pull them off, clean them and clean the lenses. You can also stick them to a TV screen to charge them before installing.
wish i would have seen this yesterday. i just installed the static cling ones on my car last night. i washed it first, so i'm pretty sure everything was good, but i guess i'll see.
yah i got the plexi glass one.i do have a lift i can use i was reading a write up about taken off the airducts and all that and i was thinken there had to be a simpler way..i know their spring loaded and i mite try what 4U2ENVY suggested =)
Where can I find the static cling blackout turn signals for my 2004 Z06?
Thanks.
