removing balancer on 2000
Old Jul 6, 2010 | 02:14 PM
futuretech's Avatar
futuretech
Default removing balancer on 2000
Engine will be out of car. What is the correct puller to remove balancer. I also recall being told I need a new bolt.
Old Jul 6, 2010 | 02:32 PM
Patches's Avatar
Patches
I've pulled a couple of stockers with the pulley below. I also made my own installation tool with metric threaded rod, washers and metric nuts. You'll need to buy a new GM replacement bolt (one-time TTY bolt) or a reusable bolt from ARP.
Follow the instructions in the manual closely if you want a reliable r&r. Plus, I would drill and pin the new pulley while your at it.
Old Jul 6, 2010 | 02:40 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You're going need something to hold the flywheel from moving so that you can get the balancer bolt out and in. GM makes a special tool to do the job.
Don't rememebr the Kent Moore Tool #.
Old Jul 6, 2010 | 02:49 PM
futuretech's Avatar
futuretech
Drill and pin? new one for me please explain.
Old Jul 6, 2010 | 02:50 PM
futuretech's Avatar
futuretech
Are you talking about the "flywheel turner" that grips a couple of teeth on the flywheel? Oops, I jsut saw the kent moore itme online. Complete different. Anything (safe) that I can use for a one-time removal?
Old Jul 6, 2010 | 04:12 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No, it's a piece of aluminum that with teeth that replaces your starter.
http://www.etoolcart.com/flywheelhol...j-42386-a.aspx
Old Jul 6, 2010 | 04:21 PM
futuretech's Avatar
futuretech
Thanks for the clarification. I much prefer spending the $100 versus trying the "screwdriver" method recommended the neanderthals on LS1tech.
Old Jul 6, 2010 | 04:29 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's a great tool for doing clutches too.
Old Jul 6, 2010 | 04:54 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
That is the puller - I had to buy one a few weeks ago when I pulled mine off and replaced it!
Three JAW
Thanks,Matt
Old Jul 6, 2010 | 05:26 PM
Patches's Avatar
Patches
The LS engines don't key the pulley to the crank so there is always the possiblity of the pulley loosening and eventually spinning free of the press-fit used to hold it in place on the crank snout. It became common practice years ago to drill the pulley and crank snout after the pulley was installed and then inserting a hardened dowel pin in the hole to act as a sort of key to prevent the pulley from spinning off the crank snout. This is a must-do on higher hp applications. The C6 guys found out quickly in the first MY of the LS2 what pulley-walking is all about. GM had to fix some of those initially due to the same issue. Here's a couple of pics showing my buddy drilling and pinning when we installed his ATI sc several years ago. You can see the end of the dowel pin at 12 O'clock on the end of the crank in the second picture.
This is not the only method of doing this - another kit cross-drills perpendicular to the crank axis to accomplish the same task.
Here's a couple of pics of a pinning tool that comes with sc packages. I reverse-engineered and drew up one of these in CAD a few years ago.
Old Jul 6, 2010 | 08:03 PM
futuretech's Avatar
futuretech
Mine is not a high HP app. Be lucky if I get 400 RWHP out of it. Does the dowel change the "balance" of the components?
Also, I have a 150 LB torque wrench. Am I going to have to rent a 250LB one?
Old Jul 6, 2010 | 08:25 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What are your long term plans for your car ?
Old Jul 6, 2010 | 09:12 PM
futuretech's Avatar
futuretech
LOL Ok funny guy.... how can I remove it with the it in the car to make more room for the engine removal (top) ?
Old Jul 6, 2010 | 09:15 PM
futuretech's Avatar
futuretech
Still laughing...
Old Jul 6, 2010 | 09:38 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Still laughing...
I have all the tools you'll need to the job including the crank pinning device.
Basically, you have to disconnect battery, pull starter, and rack out of the way to access the crank.
Here's a link to the info on How to.
http://ls1howto.com/index.php?article=1
Old Jul 6, 2010 | 09:39 PM
Patches's Avatar
Patches
It's a 1/4" dia. x 1/2" long SS dowel so it's so close to the drilled out mass and so close to center that there's no net change in balance. I have seen LS1 (the one pictured above, for instance) go well beyond 7K rpm with no issues.
The torque wrench is the right tool to use but that's not the final true verification that you've installed the pulley properly. Technically, you should have the prescribed tools in the SM for all this but I doubt very few here do. The 240 ft.lb. spec is designed to push the new pulley onto the crank snout a certain distance before doing the final torque/TTY part. The SM calls for a distance check after the first torque of 240 ft. lbs. After using my installation tool, I torque the bolt (using the old, used TTY bolt for this first part) using a strong breaker bar or equiv. and check the distance until I'm within spec.
The spec for distance from the pulley to the crank snout end after the 240 ft. lb. tug.
You then install the new bolt, then torque it 37 ft. lb. and then another 140 degrees. I marked my underdrive pulley with a marker before the 140 degree torqueing so I knew how far to go.
I can send you the SM procedure if you want it.
Old Jul 6, 2010 | 11:23 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
^ that's if you use the stock bolt. I recommend the ARP bolt as it is re-usable in case you ever have to fix or do anything in there.
Old Jul 6, 2010 | 11:30 PM
futuretech's Avatar
futuretech
Thanks, I have the SM
Old Jul 6, 2010 | 11:56 PM
Patches's Avatar
Patches
Absolutely.
To removing balancer on 2000
