~ ~ Anyone Used SEAFOAM ~~
Old Jul 7, 2010 | 04:04 PM
Vette_Fan's Avatar
Vette_Fan
Default ~ ~ Anyone Used SEAFOAM ~~
Hey guys,
My baby is a 99 A4, with 48K miles on it. It's due for oil change. I figured I'll do a Seafoam, before changing oil.
I've read a lot of articles that it's good. I've also read about the Methods on how to use it. But I'm not that smart . I can understand putting it into the crankcase (oil), and gas tank... but I can't seem to understand how you suck it into the intake. I know some of you will say brake booter, or something like that. I still wouldn't know... can someone give me more specific (detailed) diagram, or understanding on "How To Use Seafoam"?
Thanks a lot in Advance!
Old Jul 7, 2010 | 04:31 PM
warlock007's Avatar
warlock007
pm'd you
Old Jul 7, 2010 | 05:53 PM
tlc0706's Avatar
tlc0706
And the stuff works..Install is relatively simple....Brake booster is on engine side of firewall....about a foot in diameter w/brake fluid reservoir on the front....15/32 hose attached to front of booster....Have a partner set rev's about 2000 while slowly pouring about in 1/3 of can and immediately shut off. Wait 30 minutes (some wait overnight) start and you will probably see a lot of white smoke.... Pour 1/3 in oil - 1/3 in gas......drive a while and change oil....GL
Old Jul 7, 2010 | 06:22 PM
warlock007's Avatar
warlock007
the front PCV at throttle body is better to do it with. sent my number to explain but it is easy.
Old Jul 8, 2010 | 02:22 AM
TheFlyingDutchman's Avatar
TheFlyingDutchman
I just gave my c5 the seafoam treatment last weekend, changing the oil this weekend. I connected a rubber hose with a funnel attached to it to the pvc inlet on the side of the intake manifold. Like tlc said, 1/3 into the intake, 1/3 into the gas tank, and 1/3 into the crank case. There are so many threads on this topic in the forums. Most seem to recommend the pcv inlet on the intake.
Old Jul 8, 2010 | 03:15 AM
Corvette Don's Avatar
Corvette Don
I only use it through the gas tank, 2 cans 2 different fillups with only ~5 gallons each every ~5k miles or so. I drive my car hard enough that I prob dont need it.
Old Jul 8, 2010 | 04:24 AM
warlock007's Avatar
warlock007
When I did mine it was recommended by seafoam to put full can in crank not less than 50 miles but they said they saw better results with at least 500, also one can in gas tank as with the ethanol in the mix now it takes a bit more to do it's job. As for the intake it took 2/3 can before the white smoke started to exit the exhaust as per instructions given to me, get hose put end on front pcv intake on rear side of throttle body, engine running at 2000 or so stick other side of hose into bottle when you see the smoke shut car off and wait at least 2 hours. Personally I waited 6 but my car has 130000 on it and wanted to let it soak good. Everyone has there own way.
When I had it street tuned they said there was no detonation issues at all which tells me it worked out great.
Good luck and it's worth it
Old Jul 8, 2010 | 06:13 AM
99FRC Newb's Avatar
99FRC Newb
i drive my car pretty hard, so i don't know how much it really helped. i seafoamed right before i took my heads off at 40k miles and everything was spotless.
Old Jul 8, 2010 | 06:45 AM
87gtNOS's Avatar
87gtNOS
I sell and use lots of Seafoam!! I put it every tank of fuel in my boat.
I did my Tahoe through the brake booster hose. You simply hold the can about 6" from the hose with your thumb over the can and slowly let the seafoam pour towards the open hose. You don't need to rev the car, as the application the seafoam at this rate should not stall the car.
What happens is as you slowly pour the liquid (controlled by your thumb on the can) it will get sucked into that vacuum hose!!! It virtually streams or turns to a mist as it gets sucked in!!
I used 1/2 can on the Tahoe....and put the rest in the fuel tank. We did mine as a demo, and only left if shut off for 10 minutes.
Start it up, and go for a good blast for 10 minutes and all the smoke will go away!!!
It seemed to improve 'tip-in' throttle response on mine.
Old Jul 14, 2010 | 02:47 AM
Vette_Fan's Avatar
Vette_Fan
...so I took off the plastic covers on both side to look for the pcv intake tube. I'm guessing it's towards the passanger side. But there are 2 tubes. One is a thin tube from throtle body to valve covers, the other also comes out of throtle body and has a big plastic thingy on it and goes into the valve covers area too. The 2nd hose is a little bigger in diameter. So which is it? I really wana do the Seafoam thing...
Also I noticed some oil/grime on my valve covers/heads area. Does that mean I'm leaking oil from somewhere? It's got original 48K FREEWAY miles. I was thinking Gunk Engine cleaner foam all over it, and then spray with water hose. Plz advice me how to protect coils, alternator, or any other electric parts.
Thanks guys!
Old Jul 14, 2010 | 08:15 AM
runner140*'s Avatar
runner140*
I've used SeaFoam for many years....on my C-4 and other engine applications. I've never put it in the crank case.....1/2 can in the brake booster hose and the other 1/2 in the gas tank. After using 1/2 can in the brake booster hose, turn off the engine for five minutes and let it soak, then start up and drive for a few minutes.
Old Jul 14, 2010 | 08:23 AM
CAP94's Avatar
CAP94
Can someone post up a pic of which inlet to use?
Old Jul 14, 2010 | 09:06 AM
vettestream's Avatar
vettestream
+1
Old Jul 14, 2010 | 09:23 AM
Dominic Toretto's Avatar
Dominic Toretto
-Alex
Old Jul 14, 2010 | 09:56 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Originally Posted by AlexSmith
-Alex
+2
Old Jul 14, 2010 | 10:06 AM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Snake oil Could cause hydrolock. I tried it twice and didn't notice results.
Old Jul 14, 2010 | 02:08 PM
Bluefire's Avatar
Bluefire
Me thinks maybe you did it wrong. The product works well. It got rid of my pre-detonation as advertized. The smoke show was too.
To ~ ~ Anyone Used SEAFOAM ~~
Old Jul 14, 2010 | 06:40 PM
Chicago1's Avatar
Chicago1
If you use the brake booster from what I read so correct me if I'm wrong doesn't get into all the cylinders. Also what do you guys mean ", 1/3 into the intake, 1/3 into the gas tank, and 1/3 into the crank case.
I understand the "crankcase"(pvc correct?) "gas tank" well durrrr but what's this intake? I thought using the pcv would take care of that??
Old Jul 14, 2010 | 06:58 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
They say
1/3 in the crankcase = 1/3 can in the oil
1/3 in the intake = 1/3 can through PCV
1/3 in gas = 1/3 can in the fuel tank
Old Jul 14, 2010 | 07:04 PM
87gtNOS's Avatar
87gtNOS
Gentlemen....read my instructions above....you don't POUR the liquid in....pull the vacuum hose off the brake booster....
Start the car.
hold open can 4" above the vacuum hose with your thumb over the can top.
slowly allow the seafoam to pour out of the can towards the vacuum hose.
you will see the seafoam turn to mist as it is sucked into the engine!!
the engine may chug a bit.....keep pouring slowly....takes about a minute or so...
Shut car off. Let sit for desired amount of time. I left my Tahoe for 10 minutes only, as we were using it as a demo. Some people leave it overnight.
Start car up, go for a drive and WHALE on it!! About a minute later the car will stop smoking.
As a side note, one of my Salesmen tells a tale of a Honda locking up from Seafoam...however, the story goes that he basically poured the liquid right into the intake...not allowing it to mist.
