AC regcharge procedure
Old Jul 7, 2010 | 10:47 PM
futuretech's Avatar
futuretech
Default AC regcharge procedure
I am removing the AC pump from my C5 when I swap engines. What is the pest way to recharge it? Take it to a pro or...?
Old Jul 7, 2010 | 10:55 PM
dougbfresh's Avatar
dougbfresh
If it works now you won't have to.
Old Jul 7, 2010 | 10:57 PM
futuretech's Avatar
futuretech
I am disconnectin the line to remove the pump. I till we off for a week. I suspect I will need to at least add coolant if not purge the system.
Old Jul 7, 2010 | 11:36 PM
Blown 346's Avatar
Blown 346
The proper way to do this....
Evacuate the system of all freon,pag oil, moisture.
Refill with pag oil, remove moisture, do a system check for any leaks. Fill with freon.
Old Jul 8, 2010 | 04:03 PM
futuretech's Avatar
futuretech
Is there a procedure that oulines the steps?
To AC regcharge procedure
