Had 4 Post Lift Installed
Old Jul 10, 2010 | 11:14 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by Patches
Black was custom when I bought mine. My understanding is they are no longer built stateside.
Patches, how are the floor tiles holding up against tire heat? Any burn marks? I have the rubber floor mats in my garage over residential grade builder epoxy as the tires were lifting the epoxy especially when wet. The pads prevent that, however I have tire burn marks now. I was thinking floor tiles, however I don't want to have burn marks on those.
BTW - Bend Pak makes a great lift, however is it just me or is that the worst name possible for a car lift..."BEND PAK". Sounds like an industrial compressor.
Old Jul 10, 2010 | 11:19 AM
steve8's Avatar
steve8
Those lifts look great!
Have to consider one for the next house.
What extras/options do you recommend?
Old Jul 10, 2010 | 01:25 PM
TBZ06's Avatar
TBZ06
Default 4 Post Lift
I have had my Bend Pak HD9 4 Post lift for about 4 years. It's great for storage of my vette and for servicing. It will also be great for the addition of another vette in the future. No regrets.
Old Jul 10, 2010 | 03:08 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Have had mine for a couple years now. Some tips: buy some solid rubber wheel chocks...get 4 of them...put some yellow or red tape on the sides of the chocks so if you forget the chocks are there you should see them when you are at the lift's lowering control. 2) Mark your safety stops with bright paint/tape at each post so you can see that your safety levers are seated at all 4 posts...do a walk around before standing underneath. 3) Keep the radios and other distractions to a minimum when using the lift...it's easy to hit the wrong button, or to lower it too fast when not paying attention. 4) If you have a riding mower, make some strong cross member ramps to park the mower on, then lift it to clean the grass from the deck. 5) also, the lift is great to stand on when adding lighting, painting the garage ceiling, etc. 6) If you have a floor you do not want damaged you can leave the ramps ever so slightly raised when it is down...this will take the load off the tiles, concrete, etc and you can still park on it and back off with no side effects. I could go on and on, but the best use is for detailing the wheels and doing brake work...everything is at shoulder height..no bending/crouching/kneeling!!!!!!
Old Jul 11, 2010 | 07:30 PM
Patches's Avatar
Patches
Bend Pak makes industrial pipe benders as a primary business - thus, the name.
I have some very slight discoloration after four years of constant hot-tire parking on a couple the beige-colored tiles, although, I have not given the spots the thorough cleaning they need. It barely shows - you need to walk up to them to see it. It's all moot, though - it's so easy to replace tiles anywhere in the matrix of the floor that you can pop a couple new ones in within a few minutes. I had to do that recently. The light beige tends to show dirt more than the darker colors but it's really easy to replace them if damaged so, no big deal.
Old Jul 11, 2010 | 07:48 PM
Greg F's Avatar
Greg F
Ok.. all finished. Had to move the lift a little, as the car mirror wouldn't clear. Using a line on the driveway to align the car, as the garage is too dark to backup safely.
Old Jul 11, 2010 | 08:05 PM
Greg F's Avatar
Greg F
Is anything built state site anymore? Even they assemble them locally to make them look like they're American made, they still pour the steel and stamp the fitting in china.
Old Jul 11, 2010 | 08:28 PM
Patches's Avatar
Patches
Good-looking setup, Greg. Looks like you placed it perfectly to leave as much room as possible on the left side.
Once you get used to having it there, you'll wonder how you ever got along without it.
Old Jul 11, 2010 | 09:42 PM
steve8's Avatar
steve8
Why not just drive on?
Old Jul 11, 2010 | 11:10 PM
Greg F's Avatar
Greg F
Tried it this morning, that's why the car is nose in on some pictures. Even with the front end rubbing against the back wall the garage door hits the glass. There is a beam a few feet back from the front of the house which wastes about a foot of height. I had the door tucked all the way up to the beam and it only fits with the front facing out.
Old Jul 11, 2010 | 11:43 PM
rpm462's Avatar
rpm462
Very nice!! One day......
Old Jul 12, 2010 | 03:00 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
My wife asks me the same question. Takes a little practice and I open the door to look at my alignment or even get out to check but it gets easy after two or three times.
You get used to it pretty quick, it's almost easier than having someone out there trying to guide you.
Originally Posted by Blew by you
How much did you spend, and why do you need it? will it offset the cost of the lift?
I spent about $2k on mine. It there mainly for storage, but I use it for maintenance of my other vehicles as well. Yes it was MUCH cheaper than building another garage or adding on, or renting a building across town (which I would worry about security of).
Driving on works great...if your garage is deep enough...mine isn't. The only way for the the lift to raise all the way up (10'3" ceilings) and the garage door to open all the way is to back on, so the door goes over the lower portion of the hood.
