A4 owners question
Old Jul 12, 2010 | 09:07 AM
oldvettedrvr's Avatar
oldvettedrvr
Oldtimer
Default A4 owners question
How much does your A4 "creep" in gear at idle???
I have a '98 that idles around 750 and I have to keep a good amount of brake pressure to keep it from moving even on a slight incline. If I let it go it will get up to about 25MPH. Is this about normal??
Old Jul 12, 2010 | 09:14 AM
stick152's Avatar
stick152
Sounds 'bout right for mine also. I haven't checked the speedo, but I will on my way home today.
[EDIT] Mine's an '03, btw.
Old Jul 12, 2010 | 09:17 AM
MNR's Avatar
MNR
If you take your foot off the brake you can go 25mph?? That sounds really high. I will check when I get her out today.
Old Jul 12, 2010 | 09:32 AM
steve8's Avatar
steve8
Don't have an automatic, but 25 mph does not sound right to me.
Old Jul 12, 2010 | 09:38 AM
jrose7004's Avatar
jrose7004
25 MPH uphill? Sounds a little much. I don't think mine would do that.
Old Jul 12, 2010 | 09:43 AM
YNOT2K's Avatar
YNOT2K
what gears do you have?
Old Jul 12, 2010 | 09:59 AM
romeospete's Avatar
romeospete
Default Sounds a little fast!
I just took mine out on our street which is flat and level and when I let off the gas in drive it went up to about 6-7 mph and continued at that speed and reverse is about the same. My car has the performance axle ratio, which I don't know if that makes any difference.
Good luck with that!
Old Jul 12, 2010 | 10:49 AM
damilleniumboy's Avatar
damilleniumboy
Mine gets up to 13-15mph if I just let off the brakes. When i'm going down the road on a city street, pretty level, if I let go off the gas at about 27mph, it will do about 25 while idling in another gear othen than 1st. It's 2nd or 3rd, idk?
Old Jul 12, 2010 | 11:10 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I have a '98 that idles around 750 Is this about normal??
Is it 750 in Drive or Neutral?
750 RPM in Drive would be a little high if your engine is stock.
Old Jul 12, 2010 | 11:17 AM
japc5's Avatar
japc5
My idle in drive is ~600 if I take my foot of the brake while in drive on level ground it will creep a little, never really tested to see how fast it will go. On a steep hill I have no forward motion on a slight incline it will creep a little. I have 3:15's in the rear.
Old Jul 12, 2010 | 11:47 AM
oldvettedrvr
Oldtimer
I have the 2.73 rear.
750 RPM in neutral & its stock
Actual MPH at idle on level ground is somewhere between 20 & 25, 25 may be a little high (was just a guess)
Old Jul 12, 2010 | 11:51 AM
corvettebob1's Avatar
corvettebob1
No it's not normal if your engine is stock it should idle ~550 W/AC on and in gear.
Old Jul 12, 2010 | 01:38 PM
Bluefire's Avatar
Bluefire
Do you have a cam? Stall converter?
Old Jul 12, 2010 | 03:26 PM
PostShawn's Avatar
PostShawn
Mine changes all the time. On slight inclines it will still creep usually but never 25mph, not even when level. Maybe 5-10mph when level and 2-4mph when on a very slight incline. I almost find it more amazing that on a large incline it will sometimes stay still and not roll backwards.
Old Jul 12, 2010 | 04:31 PM
MNR's Avatar
MNR
I noticed that as well. Maybe some kind of hill start assist or something?
For the record OP, I have the 2.73 axle and in drive it creeped about 6-7mph.
Old Jul 12, 2010 | 05:08 PM
chaase's Avatar
chaase
St. Jude Donor '12
Old Jul 12, 2010 | 06:52 PM
moserbe's Avatar
moserbe
Sounds like you need to have a mechanic look at it. Not normal.
To A4 owners question
Old Jul 13, 2010 | 11:38 AM
Mike Mercury's Avatar
Mike Mercury
at 100% stock, my A4 would idle at 600/650 rpm - in gear & stopped
Old Jul 13, 2010 | 11:50 AM
stick152's Avatar
stick152
Got a chance to check mine yesterday on the way home from work. It idles at ~600 RPM in gear and creeps along at ~5 mph on a level surface. It's an A4, all stock.
Old Jul 13, 2010 | 12:13 PM
25 mph seems awful high to me. I know mine doesn't get that fast when at idle and no brakes being applied. I'd say mine gets about 8 mph or so.
