A4 owners question
Old Jul 13, 2010 | 02:38 PM
C5XTASY's Avatar
C5XTASY
Originally Posted by corvettebob1
No it's not normal if your engine is stock it should idle ~550 W/AC on and in gear.
Way too high. Is that with A/C on or off? A/C on kicks the idle a little higher, I believe, but not that high. Also, makes me wonder if the throttle body is sticking a little. Hard to believe the computer would change by itself.
Ed
Old Jul 13, 2010 | 03:05 PM
Blew by you's Avatar
Blew by you
Look at the bright side you only have to use one pedal in traffic.
Old Jul 13, 2010 | 03:13 PM
DeeGee's Avatar
DeeGee
Mine has no creep at all. I need to hit the throttle to start off
Its not happy
Old Jul 13, 2010 | 03:31 PM
Trios's Avatar
Trios
With a 2.73 axle ratio, at 750 RPM, assuming zero slip of the torque converter (which is not realistic), your speed on stock tires and wheels is 7 MPH. Adding in the slip, you shouldn't be above 5. With a 3.15 ratio, you're down to 6 MPH w/ no slip.
3rd gear at 750 RPM is 22 MPH. There's no way you're in 3rd gear after coming to a stop.
Something is wrong with this picture, mathematically speaking.
Old Jul 13, 2010 | 06:32 PM
oldvettedrvr's Avatar
oldvettedrvr
Oldtimer
A/C on..I will check the TB tomorrow..This is something that did not happen all at once, it sorta has been creeping up, so it could be the TB
Old Jul 14, 2010 | 10:19 AM
C5XTASY's Avatar
C5XTASY
Hopefully it's just a litttle bit of crud buildup.
Ed
Old Jul 14, 2010 | 11:08 AM
crosstheline's Avatar
crosstheline
How much does your A4 "creep" in gear at idle???
I have a '98 that idles around 750 and I have to keep a good amount of brake pressure to keep it from moving even on a slight incline. If I let it go it will get up to about 25MPH. Is this about normal??
Mine idles at 950 and needs to go up. No creep at all as well with the 11" 3400 nitrous converter. When I turn on the A/C it just about kills the engine. New engine only has around 500 miles on it. Damn cam and supercharger. Will fine tune the idle when I do my high speed tuning.
Old Jul 15, 2010 | 12:07 PM
oldvettedrvr
Oldtimer
I checked the TB an found "some" black gunk inside which I cleaned out. Everything else looked OK.
Idle dropped to 700rpm in drive with A/C on.
I will watch it real close an see if idle speed continues to go up before I go the shop routine.
Old Jul 15, 2010 | 04:02 PM
C5XTASY's Avatar
C5XTASY
Old Jul 15, 2010 | 05:17 PM
BenC5's Avatar
BenC5
Is it not true that GM changed something in the alternator/pulley/bracket to help the high idle/creep in the 2001-2004 GenII C5's?
Old Jul 15, 2010 | 07:46 PM
lil vette's Avatar
lil vette
Originally Posted by japc5
My idle in drive is ~600 if I take my foot of the brake while in drive on level ground it will creep a little, never really tested to see how fast it will go. On a steep hill I have no forward motion on a slight incline it will creep a little. I have 3:15's in the rear.
I am at about 625 in gear, stopped
Old Jul 15, 2010 | 08:31 PM
edram454's Avatar
edram454
Default A4
I have a 2000 A4 with dyno tune and 3:42 gears and it idles at 600 in drive and barely creeps maybe 6 miles an hour in drive and shift points and line pressures have all be done. fyi.
Old Jul 16, 2010 | 04:03 AM
  #33
Choreo's Avatar
Choreo
Originally Posted by stick152
Got a chance to check mine yesterday on the way home from work. It idles at ~600 RPM in gear and creeps along at ~5 mph on a level surface. It's an A4, all stock.
Sounds about right to me.
Old Jul 16, 2010 | 01:32 PM
  #34
oldvettedrvr
Oldtimer
OK my earlier tests after cleaning the TB were done in the garage.
I just took it out on the road and everything seems to be OK for now.
Idle speed is around 600/625, A/C on, in Drive
Idle speed forward is around 6-8 mph.
Even though I could not feel anything inside the TB it must have been something holding it open just a small amount.
Thanks for all of the input/help
Julian
Old Jul 16, 2010 | 01:42 PM
  #35
stick152's Avatar
stick152
Excellent!
Old Jul 16, 2010 | 04:17 PM
  #36
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
2002 A4 vert. 500 RPM in gear. 3:15 rear end. A/C on.
Old Jul 16, 2010 | 04:46 PM
  #37
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would say maybe mine will get to 5mph on level ground. I have to apply next to nothing to keep the car still. If you think yours will go 25 I would have to say that is not normal at all.
Old Jul 16, 2010 | 05:27 PM
  #38
mcgilles's Avatar
mcgilles
nothing to do with my vette but I've found a great variance in the creep on automatics. I had a 96 taurus which would end up going so fast with just letting off the brake that the tranny would shift into 2nd without ever touching the throttle. I currently also have a 97 SHO which as been modified with a tune and some other things but it has nowhere near the automatic pull when it gear with no throttle. I never knew what to make of that.
