Corvette C6 and C5 Custom Shift Knobs...
Old Sep 10, 2010 | 08:23 AM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Originally Posted by DeBaGo
Nice pieces. For all the A4 guys like myself, maybe you should see about including the adapter that allows you to use the "normal" shifter on an A4. You just push down the whole thing to shift. I know several online sources have them. Maybe make a package deal on shift **** and adapter for us A4 folks.
Hey, great idea....never thought of that....
I actually have those, let me see what I can do here....
Jim
Old Sep 10, 2010 | 04:01 PM
jan-db's Avatar
jan-db
Originally Posted by jrose7004
+1
Me too.
Old Sep 15, 2010 | 09:06 PM
southerncarparts
Supporting Vendor
Ok....we now have the solution for the Auto guys....
Our Corvette Auto-Manual shift **** converter will allow you to use any of the standard C5 threaded 9/16-18 shift ***** on the Automatic shifter. To change gear position, you just press down on the entire ****.
Also works on the C6 Automatic also.....Just make sure you order a shift **** designed for the C5, threaded with 9/16-18
Do not tell me I do not listen to the forum suggestions...
Old Sep 19, 2010 | 01:35 PM
yyukon's Avatar
yyukon
How about some pictures of these ***** with adaptor on a A4?
Old Sep 28, 2010 | 09:43 AM
Crusher's Avatar
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
Yes, that would be nice......Am ready to buy
Old Oct 14, 2010 | 05:33 PM
midlifetoy1's Avatar
midlifetoy1
Old Oct 14, 2010 | 09:52 PM
moserbe's Avatar
moserbe
Let's see them installed with the adapter.
Old Oct 30, 2010 | 05:01 PM
Kingman99's Avatar
Kingman99
You can count me in A4, but will need directions to put it on.
Old Nov 1, 2010 | 06:50 AM
southerncarparts
Supporting Vendor
Directions are included when you order the Auto shift **** adapter.
Jim
Old Dec 12, 2010 | 04:40 PM
6t5silver's Avatar
6t5silver
Do you have any M6 shifter ***** that will go nice with:
04 CE conv. lemans blue / shale int.
03 50th anniv. red / shale int.
Old Dec 30, 2010 | 09:39 PM
jdot's Avatar
jdot
So if I order the converter for my auto C5 it comes with clear installation directions, all parts needed for same, and any **** you sell on here will fit; am I right? Installation under an hour, just how much is required since I'm not a wrench type?
Old Dec 31, 2010 | 12:46 AM
olbear1962's Avatar
olbear1962
There is an old post I found VERY helpful on modding the auto trans shifter to accept a MOMO shift **** for the auto.
It involved cutting the white nylon "bushing" to lower the overall height of the ****, fitting to std shifter **** was too high.
This may help guys with the adaptor coupled to the many different stick shift ***** available?
Old Jan 5, 2011 | 09:49 PM
  #33
southerncarparts
Supporting Vendor
It does, and is not hard to install.....
Jim
Old Jan 9, 2011 | 06:21 PM
  #34
Paul Wood's Avatar
Paul Wood
Count me in with the auto bunch. My original is looking pretty sad.
Count me in too. Why is the A4 so hard to do? Mid America used to have one but no longer. I guess it is much easier to turn these on a lathe and ship them out and the auto requires some engineering.
Old Jan 13, 2011 | 12:24 AM
  #35
southerncarparts
Supporting Vendor
Your answer is right here....
C5 Auto Shift **** Adapter
Install the adapter and you can use any of the manual shift ***** that we offer....
Jim
Old Jan 16, 2011 | 10:22 AM
  #36
ALLEGRO's Avatar
ALLEGRO
Looks really good, but a quick question:
Does this **** sit lower on the shaft? I have cut my stock C5 shifter to shorten the throw, and am hoping that this **** would sit even lower on the shaft than the OE unit.
Thanks ahead.
Old Jan 20, 2011 | 02:26 PM
  #37
southerncarparts
Supporting Vendor
Thanks ahead.
I am not certain, as we have not tried it side by side with the OEM ****. I think it does sit a little lower, but am not positive. Maybe someone who has purchased one can give us some feedback?
Good question....
Jim
To Corvette C6 and C5 Custom Shift Knobs...
Old Apr 3, 2011 | 12:11 AM
  #38
Major Dump's Avatar
Major Dump
How hot do the stainless ***** get in the summer? I'd consider the black or white plastic ones but I'm not sure how that would look with the shale interior, the bronzed stainless one would't look out of place.
Old Apr 7, 2011 | 10:19 AM
  #39
southerncarparts
Supporting Vendor
They're metal so in the summertime sun they're going to get hotter than non-metal shift *****, so I'm sure that's worth considering.
Thanks,
Dave
Old Jun 4, 2011 | 10:29 PM
  #40
DP77Vette's Avatar
DP77Vette
St. Jude Donor '10
Nice looking shift *****. Now if someone would just come up with some different ones for the A4.
