2002 ZO6 need brake rotors..should I stick with OEM or go with an aftermarket....stock size wheels so I don't need oversize rotors,and I don't track car. THX
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Depends on what you paln to do with the car. For normal street use the stock rotors are just fine. If you plan to track the car very much I would suggest something a little more stout. Presently I'm using Power Slot rotors and have been very happy with them so far.
Agreed.Plain rotors are just fine for street use.I'm going to UG mine with the ATE rotors.Made by Continential and they are mostly std rotors with an interesting wear slot and anti-rust coating.
There are plenty of individuals using the stock rotors with more aggressive pads for track use, myself included. Run a search in the autocross/road racing section, you will see.
THX guys for all the replies,Question; is the rotor size the same as a non ZO6....I always thought the front rotors on a ZO6 where larger in diameter then the regular Corvette's
Yeah the stock rotors are ok on track. I recently found that the Centric Premium rotors (KNS brakes or Tirerack) hold up better and cost about the same or a shade less than OEM. I would use them.
All the research I've done shows the only difference in C5Z brakes is the red powdercoat. I haven't looked into Master cylinders, proportioning, or hard lines. Please correct me if I am wrong.
I ALWAYS thought c5z had different brakes than normal c5's.
