Need help with Easy Entry
Old Jul 18, 2010 | 05:42 PM
jrprich's Avatar
jrprich
Default Need help with Easy Entry
I like and use the Easy Entry feature but last week, for no known reason, it stopped moving the seat back.
It still lowers the seat and sets the mirrors and steering wheel but will not run the seat to the back.....which of course is the feature I like the most.
I do use the same fob to unlock the door and I did go into the DIC and turn EE of and then back on.........also did the fob reset.........no change.
Anyone have any ideas ?
Thanks,
Jim
Old Jul 18, 2010 | 06:19 PM
warpster's Avatar
warpster
Mine does this accasionally also, I move the seat all the way forward and back a couple of times and then reset the seat memory position.
Old Jul 18, 2010 | 08:58 PM
Blew by you's Avatar
Blew by you
Try some lube really i have the same thing happen all the time i just gave up and chalked up another one to the bad Corvette syndrome.
Old Jul 18, 2010 | 09:24 PM
McRCN's Avatar
McRCN
Mine has a mind of its own at times. Sometimes it does not go forward at startup.
Old Jul 19, 2010 | 06:58 PM
jrprich's Avatar
jrprich
I will try that, thanks
Tried it..........no luck.............
Old Jul 19, 2010 | 07:54 PM
killain's Avatar
killain
Oldtimer
Default Easy entry / easy exit problems
I had the exact same thing on my 2003 last year. Luckily the repairs were covered by my GMPP to the tune of $2100.00. They replaced the BCM and the control as well as new seat tracks, I asked if the seat tracks were bad, but the service manager said he didn't want to take a chance that they go bad, (Rocking seat problem) so he replaced them as well. Said it was GMPP, so why take a chance. Go with a new set.
Old Jul 19, 2010 | 08:55 PM
jrprich's Avatar
jrprich
That is great, but since I don't have an extended warranty, I don't have that option
Old Jul 19, 2010 | 09:17 PM
dklowrider's Avatar
dklowrider
mine does that every so often. if you pull the key and nothing happens try hitting your memory button. it should activate the easy entry.
Old Jul 19, 2010 | 10:11 PM
jrprich's Avatar
jrprich
When I pull the key it does everything it is supposed to EXCEPT run the seat back........
Old Jul 22, 2010 | 09:47 PM
jrprich's Avatar
jrprich
ttt
Old Jul 23, 2010 | 03:16 PM
jrprich's Avatar
jrprich
If I pull the key and hit the memory button it runs out the steering wheel and will move the seat forward but not backwards.
Anyone else with any ideas ?
Old Jul 23, 2010 | 05:22 PM
8VETTE7's Avatar
8VETTE7
Just on chance that there might be some codes set, did you pull them and look? There are about 2 dozen codes that the seat control module (SCM) can set including a few related to memory.
http://www.c5forum.com/ayc/dtcdic.php
Old Jul 23, 2010 | 05:51 PM
SCM_Crash's Avatar
SCM_Crash
At least once a month, I'll put the key in and instead of the seat moving forwards, it will move backwards all the way. I pull the key and it moves forwards. LOL
I just lock the doors with the fob and then unlock them and everything works right again the moment I put the key back in the ignition.
Old Jul 23, 2010 | 06:44 PM
jrprich's Avatar
jrprich
Checked the battery at rest 12.65 volts
Pulled the codes, all were History codes
58-SDM
B1001 Option Configuration Error
60-IPC
B0521 Tachometer Signal Circuit Malfunction
U1161 Loss of Communications with RDCM
AO-LDMC
U1064 Loss of Communications with BCM
A1-RDCM
B2253 Key Cylinder Switch Circuit
B2285 Battery #2 Circuit
BORFA
1096 Loss Of IPC Communications
1064 Loss Of BCM Serial Data Communication
1016 Loss Of PCM Communications
To Need help with Easy Entry
