The famous 'piston slap' - possible solution found
Old 07-19-2010, 08:53 PM
Chevy-SS
Chevy-SS's Avatar
Default The famous 'piston slap' noise - possible solution found
My car is a 2004 Coupe, stock LS1, auto trans. I bought it 18 months ago, and it has always had a VERY noticeable piston slapping type of noise while warming up. The slapping noise would still be slightly noticeable until fully warmed up to 185 degrees or so.
I had a buddy tweaking the engine settings a little, and I told him about the slapping noise. He has been working on cars for 40+ years and his family owned a Chevy dealership. He currently operates a high-performance shop where he dynoes cars, tunes, and does all kinds of other stuff. He does a lot of Vette work.
Anyway, he figures the slapping noise is mainly being caused by piston rings that are sticking. He suggested I change the oil and use the Zmax treatment (oil & gas). He swears that many of his customers have had success reducing or eliminating the slapping noise. I was very skeptical, but I changed the oil and filter, tossed in some fresh Mobil 1, and also added the Zmax to the oil & gas.
Honestly, I expected zero results, but after driving maybe 400 miles, I absolutely notice a DECREASE in the volume of the slapping noise at startup, plus the slapping noise goes away earlier in the warmup cycle. I will keep reporting on this, but I am very pleasantly surprised by the results so far. This is a cheap and easy thing to try, so if a piston slapping noise is driving you crazy, try the Zmax and oil change.
EDIT - changed "slap" to "slapping noise"
Old 07-19-2010, 08:55 PM
moserbe
Support Corvetteforum!
moserbe's Avatar
Keep us updated. I have this in my 2007 Trailblazer SS LS2.
streetstrip (02-16-2020)
Old 07-19-2010, 09:00 PM
SCM_Crash
SCM_Crash's Avatar
Piston slap is caused by the material difference between the piston and the sleeve. There was some room added between them because they expand from heat at different rates due to the different metals they're made out of.
Old 07-19-2010, 09:05 PM
itzza427
itzza427's Avatar
I'll keep this in mind,,but mine is pretty slight,,and once the oil temp hits 180,,it's pretty much gone!! I WILL be watching for any updates!!
Old 07-19-2010, 09:12 PM
dklowrider
dklowrider's Avatar
hmm. i've heard of changing oils [switching brands] having a supposedly noticeable difference in the slap, but anything i've known about it has nothing to do with sticking rings. is Zmax thin like Seafoam or thick like STP?
Old 07-19-2010, 09:19 PM
dougbfresh
dougbfresh's Avatar
If that "fixed" it, it wasn't piston slap to begin with. Look up the definition of Piston Slap.
Old 07-19-2010, 09:31 PM
damilleniumboy
damilleniumboy's Avatar
uh oh, interesting thread.
Old 07-19-2010, 09:37 PM
dklowrider
dklowrider's Avatar
well, he didn't exactly say it 'fixed' it.
Old 07-19-2010, 09:40 PM
dklowrider
dklowrider's Avatar
just like that first black cloud you spot on the horizon, you just know a storm's coming.
Old 07-20-2010, 12:12 AM
SCM_Crash
SCM_Crash's Avatar
Exactly. All sleeved SBC's have piston slap. It's not something that's fixable (or should be fixed) and in fact it is part of the design of the motor.
Couldn't agree more. There's going to be a lot of uneducated assumptions about piston slap coming. I can see it over the horizon now.
Old 07-20-2010, 06:57 AM
Mike Gallagher
Mike Gallagher's Avatar
My understanding is the cold size of the piston is smaller so the piston fits once up to temperature. Thus the piston slap before warm up.
Old 07-20-2010, 07:36 AM
Cybermind
Cybermind's Avatar
With a 2004, I would take a guess and say that what you were hearing was probably valvetrain noise (clatter) and not piston slap. I believe that GM added a dry graphite (or teflon) coating to the piston skirts on 03 and 04's in order to alleviate the noise. I think they also tightened up the tolerances. Of course, some of them still have piston slap but it is not as common as the previous years.
Valvetrain noise makes more sense if your were able to quiet it down using an oil additive. I don't think it would have worked with piston slap. However, based on my experience it probably will be a temporary solution once the effects of the oil additive begins to wear off. Just my two cents.
Old 07-20-2010, 08:32 AM
Mark C5
Mark C5's Avatar
St. Jude Donor '08-'09-'10
Sticking rings
Old 07-20-2010, 08:46 AM
Chevy-SS
Chevy-SS's Avatar
I have heard plenty of these engines with absolutely no audibly noticeable piston slap (or other noises) during cold startup. Mine, however, does make a lot of noise, so somethin' ain't quite right.
Chill out, man. Basic piston slap is simple to understand, I would bet almost every single forum member knows what causes it.
BOTTOM LINE - the guy that gave me the Zmax advice is very smart and has spent over 40 years working on high performance cars. He recently finished a 2-year stint working directly for GM. I would put him up against ANYONE on this forum for sheer volume of automotive knowledge.
I was indeed skeptical of the Zmax idea, but the noise has diminished, so perhaps my problem is actually sticking rings combined with some piston slap (or even some other problem). Draw your own conclusions.
EDIT - Just to be clear, I realize that an oil additive will NEVER fix excessive 'piston slap'.
Old 07-20-2010, 09:01 AM
Chevy-SS
Chevy-SS's Avatar
Originally Posted by Mark C5
Sticking rings
Yes, yes, this was my initial reaction too when the guy first suggested the theory to me.
But, what the heck, it's an inexpensive experiment and my ears tell me there is absolutely a difference. So I'm not laughing quite as hard anymore.
Old 07-20-2010, 10:05 AM
Dave68
Dave68's Avatar
I reduced the "slapping" noise by simply switching to a better-flowing oil filter (K&N). The noise is not gone completely, but it is certainly diminished.
Old 07-20-2010, 11:35 AM
Tech
Tech's Avatar
I installed a camshaft, longtubes and Corsa. The sound from the piston slap diminished.
To The famous 'piston slap' - possible solution found
Old 07-20-2010, 02:14 PM
AUandAG
AUandAG's Avatar
I credited the noise elimination/reduction of slap to a change from Mobil 1 to Pennzoil Platinum. You've made me realize that it may have been the switch to a Wix filter.
Old 07-20-2010, 02:48 PM
oneshot
oneshot's Avatar
I too switched to a WIX filter but I still use Mobil 1 oil and the piston slapping noise or valve train chanter is almost gone.
Louder exhaust and louder stereo will not hurt either.
Old 07-20-2010, 03:21 PM
Dave68
Dave68's Avatar
Switching from a 10W-30 to a 5W or 0W-30 or 40 weight oil will also improve flow, even at 70 degrees F. Since I never changed the oil or viscosity, I attributed the reduction in slap noise to the filter swap.
Quick Reply: The famous 'piston slap' - possible solution found
