Oil Catch Can Observation
Old Jul 20, 2010 | 11:27 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Default Oil Catch Can Observation
Guys:
I installed a CCA Oil catch can a few weeks ago.
I'm not here to start a debate on the catch cans.. just a couple observation I noticed.
1.) Less black specs on the rear of the car after driving a while.
2.) WAY less black deposits inside my exhaust tips. I polish the inside of my tips so I noticed that.
Anyone else notice the same after putting on a catch can ?
Toque
Old Jul 20, 2010 | 11:31 AM
SeanMounce's Avatar
SeanMounce
This is the first post that has actually made me want to install one.
Hopefully this one doesn't turn into the normal arguement.
Sean
Old Jul 20, 2010 | 11:34 AM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
I get the black spots on the rear too. Good to know that a catch can can reduce that. Thanks for heads up
Nick
Old Jul 20, 2010 | 11:45 AM
4 KRUSIN's Avatar
4 KRUSIN
Hmmm! Possibly going on to my "to do" list. Hope to see some more positive comments.
Old Jul 20, 2010 | 11:48 AM
Toque's Avatar
Toque
Originally Posted by DevilDog II
The back of my car is much cleaner since I added a catch can. Now if someone can design one for dirt, grass, etc.
Taken from post
http://forums.corvetteforum.com/1574754388-post15.html
Toque
Bill Vett's Avatar
Bill Vett
Mark, I did notice that there was less black spots on the rear facia, my car is white so I notice less spotting. I have B&B exhaust and cleaned the inside of the pipes last month for a big show. On Saturday night a guy joked with me about cleaning in inside and how clean they were, I did not clean them sine June and about 300 miles. I can only guess that it's the catch can that has made everything out back cleaner.
Bill
Old Jul 20, 2010 | 11:49 AM
moserbe's Avatar
moserbe
Definately catches the oil.
Old Jul 20, 2010 | 12:19 PM
larrybee's Avatar
larrybee
I noticed greatly reduced spots/tip dirt. So its gotta be doing good for the intake manifold.
Old Jul 20, 2010 | 01:08 PM
Toque's Avatar
Toque
Last time I had my throttle body off, I flashed a flash light into my intake manifold. There were "pools" of oil inside my intake. About the size of silver dollars or larger. I still want to take my throttle body off again and see if I can clean that out a bit.
Originally Posted by 8VETTE7
Don't forget to check the catch can every now and again and dump what you have collected.
Will do
Old Jul 20, 2010 | 01:11 PM
jellis's Avatar
jellis
the only problem i have is the ability to drain which is a PITA. otherwise, i love the job it does.
Old Jul 20, 2010 | 01:36 PM
jjmoberg's Avatar
jjmoberg
I need to check mine. I get an ounce or two of oil every 3 or 4 thousand miles.
Old Jul 20, 2010 | 02:05 PM
Don't have a catch can on mine yet, but I've seen them on other cars and yes, they do catch the oil very well. Hopefully will be getting one for mine in the near future.
Old Jul 20, 2010 | 03:14 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
They hard to install?
Old Jul 20, 2010 | 03:45 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
[QUOTE=Toque;1574755403]Last time I had my throttle body off, I flashed a flash light into my intake manifold. There were "pools" of oil inside my intake. About the size of silver dollars or larger. I still want to take my throttle body off again and see if I can clean that out a bit.
Exactly the reason for a good Catch Can
Old Jul 20, 2010 | 04:14 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Originally Posted by Toque
Guys:
Toque
Here you go
http://www.customcorvetteaccessories...lcatchcan.html
Peace
Chip
__________________
..................Click for
Old Jul 20, 2010 | 04:27 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Try a turkey baster , I don't have to take the darn thing off this
way.
Old Jul 20, 2010 | 04:48 PM
wisvette's Avatar
wisvette
I would say they are not hard to install. I followed Dave at Conceptual Polymers install, he was helpful and it worked out great. The can stays very cool as I have it installed.
To Oil Catch Can Observation
Old Jul 20, 2010 | 05:41 PM
04 commemorative
St. Jude Donor '17
I just installed as per Chips install instructions and all seems well. I do think I will try the turkey baster method to remove the caught oil tho.
Old Jul 20, 2010 | 05:45 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Good observation - less going into Intake less going out the pipes and having to be burned by the cats
Thanks,Matt
Old Jul 20, 2010 | 05:47 PM
04 commemorative
St. Jude Donor '17
So how often should the can be checked ?
By Michael S. Palmer | 2026-06-03 11:00:24
