HVAC code B0361
Old Jul 21, 2010 | 05:41 PM
UM Rebel's Avatar
UM Rebel
Default HVAC code B0361
I displayed computer codes this morning. Noticed I have an HVAC code B0361 history. I reset it several times but it always comes back ... always shows history. A/C seems to be working fine. Believe me, I would know if its was not. It's 100 degrees outside! Just wondered if this is something I sould be concerned about.
Seth
2004 Lemans Commemerative Convertible
Old Jul 21, 2010 | 07:20 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
That's the left actuator short to ground code. So long as your temps are the same out of both driver and passenger side vents, I wouldn't worry about it.
If the temps start to change, then you'll probably end up replacing the actuator, which is pretty common.
