Defective frame welds
Old Jul 25, 2010 | 12:18 PM
bassfisher's Avatar
bassfisher
Default Defective frame welds
It looks like I've been hit by the defective weld problem on my 2000 Convertible. Found a right side rear wheel upper A-arm bracket detached from the frame. Looks like the factory welds didn't have good penetration causing the failure. Thank God it didn't completely fail while driving.
Looks like the same problem reported by others:
http://forums.corvetteforum.com/c5-t...uspension.html
http://forums.corvetteforum.com/c5-g...ty-recall.html
My questions for the forum:
1) Has anyone had success getting GM to pay for this repair?
2) Is there a recall or service bulletin for it?
3) What is the best Corvette frame shop/frame welder in the Dallas-Ft. Worth area?
I am the original owner so I know the problem isn't related to prior crash damage or abuse.
Old Jul 25, 2010 | 12:34 PM
Phanni's Avatar
Phanni
Dang,
I'm pretty sure I'd be getting in contact with GM.
Old Jul 25, 2010 | 12:38 PM
BHRZ06's Avatar
BHRZ06
Contact gm that is going to be a major major repair probably consisting of replacing the bad rails and brackets due to cracking. Lots of welding sorry man
Old Jul 25, 2010 | 03:25 PM
paint-tech's Avatar
paint-tech
Its not as bad as it looks. Any good frame shop or race shop can do this repair. To repair the rail a small hole is drilled at the end of each crack to stress relieve then its cleaned and welded. Tower is cleaned up and welded back in place. Simple fix...... As far as GM honering a 10 year old car for workmanship it will not happen sorry. It should be a 4-6 hour job and most shops charge 80.00-100.00 per hour in this area. good luck and inspect the rest of the welds on the car.
Old Jul 25, 2010 | 09:52 PM
bassfisher's Avatar
bassfisher
Thanks Paint-tech - kind of what I figured. I'll give Chevy a call on Monday just for grins but I'm not expecting much. I'm more interested in finding a good welder to do a good job.
Old Jul 25, 2010 | 10:10 PM
I too doubt GM will do much if anything, but hey, worth a shot. Otherwise, good luck getting the car repaired.
Old Oct 17, 2010 | 03:23 PM
bassfisher's Avatar
bassfisher
I wanted to report back on the outcome of this. I didn't do anything for a couple months because we were very busy with other stuff but after a lot of research I took it to Corvette Corner in Rowlett, TX. These guys did an awesome job, great communication while they had the car. I'm very pleased and happy to have the car back and handling great.
Old Oct 17, 2010 | 03:40 PM
DeltaBravo's Avatar
DeltaBravo
PICS?
Old Oct 17, 2010 | 03:46 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
What was the cost for a repair like that?
Old Oct 17, 2010 | 04:18 PM
UniqueDoug's Avatar
UniqueDoug
Old Oct 17, 2010 | 08:41 PM
bassfisher's Avatar
bassfisher
$900 including 4 wheel alignment.
Old Oct 17, 2010 | 11:16 PM
Cosmic Charlie's Avatar
Cosmic Charlie
How did you find the problem ?
Noise ?
Handling ?
pictures sure looked awful / even dangerous ?
glad you & the ride are good to go !
Old Oct 10, 2011 | 10:48 PM
wtwosilius's Avatar
wtwosilius
2nd Gear
Default 2000 conv. frame failure
My son in-law just purchased a 2000 conv. 3rd owner, clear car fax, garage kept, 29,000 mile car. The rear upper a-arm bracket that is supposed to be welded to the frame rail failed. The pictures look very similar to the pictures already posted. This seems to me to be a problem that Chevrolet does not wish to address. We are presently in the process of negotiating with a dealership.
Old Oct 11, 2011 | 09:38 AM
rebelheart's Avatar
rebelheart
Old Oct 11, 2011 | 10:35 AM
cdkcorvette7's Avatar
cdkcorvette7
Good luck with the repair. Find a good welder and it should be good as new.
Also, you should probably start your own thread next time. This one is over 45 days old so it'll probably be locked soon.
Old Oct 11, 2011 | 10:42 AM
4SFED Z's Avatar
4SFED Z
Thats looks nasty. Doesnt hurt to contact GM.
Glad I own a 02
Old Oct 11, 2011 | 11:06 AM
76 VETTE's Avatar
76 VETTE
Wow!Glad you were able to get it fixed.Gotta check mine.
To Defective frame welds
Old Oct 11, 2011 | 11:15 AM
mikelmco's Avatar
mikelmco
How common is this? Is it only on the 2000 verts?
Old Oct 11, 2011 | 08:52 PM
bassfisher's Avatar
bassfisher
Good luck - if you find a good shop that you trust with the welding it's honestly not that big of a problem.
Old Oct 11, 2011 | 10:50 PM
rtpassini's Avatar
rtpassini
St. Jude Donor '11-'12
that kind of repair is too big for me to put up front. that is something GM should warranty. Just terrible.
Also curious what years or models should be concerned with this and how or what to look for. i.e. shaking, poor handling, etc etc
