Turn signals???????
Old Jul 26, 2010 | 08:58 PM
Rambo77's Avatar
Rambo77
Default Turn signals???????
Has anyone had any trouble with your turn signals? My c5 is blowing the bulbs up, not just burning them out but blowing them up. What gives?
Old Jul 26, 2010 | 09:02 PM
jornahow's Avatar
jornahow
There are many threads on this topic: briefly the incandescent bulbs melt the top of the housing, allowing water to enter. Most likely your bulbs blow soon after you have washed the car. Solution; pull the housing and epoxy the top where it has cracked/melted. Or better yet, get new housings from JWMotoring and put in LEDs that won't melt the new ones.
Old Jul 26, 2010 | 09:07 PM
Rambo77's Avatar
Rambo77
I'll definetly check out the new housings, but I tried LED's the last time and they lasted longer but still blew.
Old Jul 26, 2010 | 09:12 PM
Rambo77's Avatar
Rambo77
I looked on JW and couldn't find them?????
Old Jul 26, 2010 | 09:18 PM
jornahow's Avatar
jornahow
Here's the page with bulbs, housings etc. As to the LED bulbs - I don't think they like to get wet, just takes longer to fail.
http://www.shop.jwmotoring.com/categ...2?categoryId=4
Old Jul 26, 2010 | 09:25 PM
Rambo77's Avatar
Rambo77
I'm sorry, I was looking for the socket itself. Do u think that my sockets could be bad or just the housing?
Old Jul 26, 2010 | 10:30 PM
jrprich's Avatar
jrprich
If you need a new bulb socket you may find one at your local auto parts
Old Jul 27, 2010 | 08:22 AM
The turn signal housings also have a tendency to just crack over time and that allows moisture inside.
Old Jul 27, 2010 | 08:24 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
You probably have a crack in the top of your housing from the heat generated from the bulb. When water is introduced the bulbs blow.
Our corners and led packages help stop this. I would check the sockets as well for corrosion etc. If they look bad I would go ahead and replace those too. They're fairly cheap.
Old Jul 27, 2010 | 02:34 PM
UM Rebel's Avatar
UM Rebel
I'm guessing this is your problem ... bulb heat cracks the housing then water gets in.
If its not too bad, you can patch it with silicon sealer. Otherwise get new fixtures. I got a set for about $60. LED's will keep it from happening again, but then comes another issue. Signals will hyperflash like when a bulb is out. Then there's a bunch of crazy stuff to solve that, new flash, balast resistors,...
Easiest thing to do is pull fuse #2 so Daytime Run Lights are off.
Old Jul 27, 2010 | 02:56 PM
DeeGee's Avatar
DeeGee
Or inhibit the DRLs so there's not so much heat
I live in England and we have RAIN. I haven't had a problem
Easiest way is to pull the A2 fuse on the engine panel
Old Aug 17, 2010 | 12:09 PM
gkhutch's Avatar
gkhutch
5th Gear
I have a used 2001 and the front right turn signal isn't working. I noticed this due to rapid flash on the dash. Does this mean a previous owner installed LED lights? More importantly, I simply wanted to remove the bulb so I could replace it, but I don't know how to even remove the bulb. I don't have an owners manual, but I downloaded one for another year (2000). I can't get my hand in edgewise to remove the bulb. Any advice?
Old Aug 17, 2010 | 08:31 PM
01magnetic01's Avatar
01magnetic01
Go in through the brake cooling duct, just push the hose back and reach in to the left you will be able to feel the socket, you will have to squeeze and twist (I think it's counter clockwise) and the socket and bulb will drop down out of the housing, there is enough slack in the wiring to pull it out through the duct, change the bulb and reverse the process. Takes a couple of minutes.
Oh, and the rapid flashing is probably from a burned out bulb....more than likely not LEDs.
Old Aug 17, 2010 | 08:43 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Best thing to seal it is "Ultra Copper". It will seal the crack and resist heat best to avoid recracking.
Old Aug 17, 2010 | 08:46 PM
01magnetic01
To the OP, it sounds like it's your sockets shorting out, local parts store (generic chevy), just make sure they are triple function.
Old Aug 17, 2010 | 09:24 PM
calivette805's Avatar
calivette805
Great post explains why I've gone threw many bulbs.
Old Aug 20, 2010 | 06:45 PM
UM Rebel's Avatar
UM Rebel
Yeh, you can go through the brake cooling duct if you have fairly small hands and writs. I can just barely do it and alway tell my g/f to check on me now and then in case I get stuck. She can get her hand in easily, but I haven't been able to make her understand how to get the socket out.
To Turn signals???????
