I have a 2001 Corvette, a month or so ago i had to replace the headlight gear. ever since from time to time the headlight motor would not go up part of the time, flip the switch and of and on and it would almost always go up on the second try.
now it doesn't want to go up at all, but if i partially raise it with the manual control, it will raise.
Is this part of a problem being caused by the turn signal flasher? I've had that anomaly happen a few times, but not consistent.
I did a search and came up with page after page of things, but none seemed relevant.
