HOw does a C5 vent engine heat?
I used a Carchip data logger (http://www.carchip.com/Products/8226.asp) to monitor engine intake air temps under a variety of driving conditions. Intake temp (OEM intake box) is a good way to determine how hot your engine bay gets, as your intake pulls air from around the intake box.
After just 5-10 minutes of slow driving on a Summer (80 degree F) day, I saw intake air temps climb up to 144F. Even after 10 minutes of highway driving, the intake air temps never got anywhere near ambient temps, so it was obvious that all that heat was not being expelled.
After finishing my CAI intake mod, which includes a scoop and cutting out a rectangular hole underneath the Halltech filter, I ran the same test. This time, intake temps never got past 110F and dropped rapidly to ambient as the car picked up speed. The engine bay remained very cool, unlike before the mod when I would return home to find the engine bay components so hot I could barely touch them.
You can achieve some of the same benefits by opening up the fog light panels. To aid in relieving underhood pressure, I cut a length of the hood weatherstripping (don't drive in the rain) - something that was recommended by a former GM employee who worked on the C5.
Of course, a heat exchanger hood would get the heat out, effectively if designed correctly.
At highway speed, I'd imagine the air rushing past the vents makes quite a suction and pulls a considerable amount of air through the vents.
Crack your window an inch on the highway and hold up a cigarette. THe suction pulls all the smoke right out.
Not that I smoke, or condone smoking in a car, let alone a Vette.
Note: Eckler's sells foglight trim pieces that have slots cut in them to replace the stock solid pieces. $75
I'm sure one of our supporting venders has them at a lower price somewhere if you ask around.
