'99 - Headlight Problem
Old Jul 29, 2010 | 09:49 AM
DJLAW202's Avatar
DJLAW202
Default '99 - Headlight Problem
Hey Guys, hope you all are doing well!!!!
I am having an issue with Driverside headlight, it is no longer going up.
The round cylinder is spinning but it wont rise, I have been manually putting it up and locking it in place by pushing the latch to lock (if thats what you call it, kinda like you do to open up a ladder).
It is not making a grinding noise so I do not know if I need to replace any gears, I did research and see the thread pertaining to that.
After I manually lock it in and turn the lights off it does go down on its on, just wont come up.
Any info/assistance would be great!
Thanks fella's
Old Jul 29, 2010 | 11:06 AM
DeeGee's Avatar
DeeGee
My guess and I could be wrong is that the gear is totally stripped and therefore not making any noise at all. The reason I'm hesitant is that normally you'd hear some grinding as the gear deteriorates. Once the teeth are gone its then silent.
I'd get a metal gear kit and strip it. Those who have done the job suggest doing both at the same time as you learn as you go along.
Old Jul 29, 2010 | 12:09 PM
DJLAW202's Avatar
DJLAW202
Which Vendors sell the kit?
Old Jul 29, 2010 | 12:24 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
PM sent
Old Jul 29, 2010 | 03:07 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
if the wheel's spinning, then your problem is mechanical. I'm almost certain the gear is completely gone.
Old Jul 29, 2010 | 04:11 PM
wclark@nj.com's Avatar
wclark@nj.com
In most cases it's the black rubber and/or the inside of the gear that holds the black rubber not the gear teeth. In either case it's time for a rebuild. Rodney's brass gear is around $45 or you can get a plastic one with the black rubber insert for around $25 (eBay).
I just rebuilt one on the car instead of removing the entire headlight assembly.
Old Jul 29, 2010 | 04:19 PM
mcgilles's Avatar
mcgilles
yep, either the gear is totally stripped or maybe the arm has slipped off the key on the output of the gear/motor assembly. take off the black plastic surround around the headlight and see if you can look where the arm is attached to the bolt going out of the gear assembly. maybe the rotation of the shaft is enough to make gravity pull the door down but the friction without the key isn't enough to raise it? if that's the case you just need to push the arm back into place and tighten the 10mm bolt.
I've never heard of a gear that was so stripped that it didn't make any noise. any problems with it prior to this? does the motor on the non-working headlight run longer than than it takes for the other one to raise?
Old Aug 5, 2010 | 02:43 AM
DJLAW202's Avatar
DJLAW202
1st time I have had this issue. Yes, the motor on the non working headlight runs longer.
Old Aug 5, 2010 | 04:02 AM
DeeGee's Avatar
DeeGee
Run down to Headlight Gears in this link and you'll get all you need:
http://forums.corvetteforum.com/c5-g...ngths-etc.html
Old Aug 25, 2010 | 10:53 AM
DJLAW202's Avatar
DJLAW202
You were correct on this one!
I got the part out the white plastic teeth looked fine, but there was all kinds of black broken rubber in there. I am ordering the brass gear today.
Old Aug 25, 2010 | 11:08 AM
wclark@nj.com
If the 4 groves on the inside of the gear are there and only the black rubber is gone, you only have to replace the black rubber (only a couple of bucks)
Old Aug 25, 2010 | 11:29 AM
DJLAW202's Avatar
DJLAW202
I think know that I have the whole thing out, I am just going to go and do the whole brass assembly anyways that way I dont have to worry about the white plastic wheel eventually going on me.
It was pretty hard (for me anyways) getting that part out without taking out the headlight assembly. I had very minimal space to work with. I may just take out the headlight assembly when I go to reinstall it, to give me some room to work with. I dont know how some people thought it was easy to do with the headlight assembly still intact.
Old Aug 25, 2010 | 11:44 AM
wclark@nj.com
I've done it both ways - for me it was faster to do it without removing the assembly. The trick is to have a 1/4" wrench for the 3 bolts – they just take time.
Just be careful to put the washers/spaces in place when you reassemble
To '99 - Headlight Problem
