Drive Belt Squeak
Old Jul 30, 2010 | 09:46 AM
JAXRWILD's Avatar
JAXRWILD
Default Drive Belt Squeak
Drive Belt Squeak, At Start Up Goes Away Once Warm Up, Whats The Best Belt Dressing ?
Old Jul 30, 2010 | 10:03 AM
YNOT2K's Avatar
YNOT2K
i'm guessing bad idler pulley (cheap and easy), or bad tensioner pulley (cheap and easy), or bad harmonic balancer (not so cheap and easy).
jeff
Old Jul 30, 2010 | 10:22 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
I heard dressing is a no no on any car
Old Jul 30, 2010 | 10:23 AM
cdkcorvette7's Avatar
cdkcorvette7
Take a bar of soap and hold it on the belt to lightly coat it while it is running (less messy than a dressing). If the squeeling stops after that you need a new belt, if it continues you need a new pulley. Try to isolate which one a replace it (not very difficult to do).
Good luck.
Old Jul 30, 2010 | 10:45 AM
bucwheat's Avatar
bucwheat
Some times a slightly warped pully will do that.
Old Jul 30, 2010 | 11:56 AM
Cheech Wizard's Avatar
Cheech Wizard
http://www.corvetteactioncenter.com/...dler+Pulley%29
Old Jul 30, 2010 | 02:48 PM
day3165's Avatar
day3165
Mine also squeaked. Changed to a Gator belt (do a search on this).
Problem solved!
Old Jul 30, 2010 | 03:20 PM
cdkcorvette7
Problem solved!
Changing the belt won't fix the problem if it's a pulley that's squeeking. Make sure you isolate the problem before you start changing out parts...
To Drive Belt Squeak
