Question about lights when unlocking car.
Old Aug 1, 2010 | 03:10 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Question about lights when unlocking car.
At a show last night we had 4 vettes side by side. When I unlock my (w/remote) 98 the backup lights come on. When my three buddies unlock theirs (99, 01, 02) the backup lights come on along with the taillights. Is that something GM changed in 99? Can a couple of 98 owners run out to the garage and check for me? Thanks.
Old Aug 1, 2010 | 03:17 PM
DeeGee's Avatar
DeeGee
This is what is says in the manual for the 02:
If you choose APPROACH LIGHTS ON, the fog lamps,
front turn signal, rear back-up and courtesy lamps will
come on for 30 seconds when you press UNLOCK on
the remote keyless entry transmitter. This will occur
only when it is dark outside
Like theirs, my 02 brings on the tails as well as the back up lamps (mine has Euro tails). Interested to hear if its different on the 98s
Old Aug 1, 2010 | 03:25 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Backup lights only on my '98.
Old Aug 1, 2010 | 05:07 PM
MAC5's Avatar
MAC5
ditto above, backup only my 98
Old Aug 1, 2010 | 06:30 PM
My '03 does the same as your's DeeGee. Never had a '98 but did have a '99. Can't remember how those worked but my '00 also turned on the rear lights.
Old Aug 1, 2010 | 06:46 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Thanks for the replies. I guess GM did change it in 99 and on up. I now know my 98 is working right.
Old Aug 1, 2010 | 06:55 PM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
Yup Back up lights and Fogs only on my 98.
Old Aug 1, 2010 | 07:52 PM
jrprich's Avatar
jrprich
My 99 does all this in bright sunlight as well as in the dark.........??
Old Aug 2, 2010 | 03:34 PM
DeeGee's Avatar
DeeGee
Come to think of it, so does mine
Old Aug 2, 2010 | 04:56 PM
mcgilles's Avatar
mcgilles
it bugs me when mine doesn't turn the lights on any time because knowing that its a corvette the first thing that comes to mind is "great, another electrical problem I have to fix" and not "its working the way it should, enough light = no need to turn the lights on"
is there anything blocking the sensor on your dash? its very sensitive, even a sticker or something like that casting a shadow on the sensor would likely cause it to think its too dark out. or the sensor may be faulty.
Old Aug 2, 2010 | 05:07 PM
jrprich's Avatar
jrprich
Nothing in front of the sensor that I can see
Old Aug 2, 2010 | 08:09 PM
jrprich's Avatar
jrprich
Is sensor is on the right side of the defroster vent ?
To Question about lights when unlocking car.
