Custom subwoofer box
Old Aug 1, 2010 | 05:33 PM
Ashc2025's Avatar
Ashc2025
Default Custom subwoofer box
I built a sub box for my Z06, wanted it to use up the extra space between the partition and the cargo compartment....all 3 inches of it. I need to work on the paint a bit more, but right now I'm just glad to have it fabricated and fitting. I have the step by step build if anybody is interested. But it was pretty straight forward with any "fiberglass enclosure" searches on Google. There are two 8" kenwoods in there and the case can actually hold two 10"s comfortably.
This is my first attempt with bondo and fiberglass so please be gentle
Look, I figured out how to add pictures
Old Aug 1, 2010 | 05:48 PM
Ashc2025's Avatar
Ashc2025
pictures won't load for some reason......:\
Old Aug 1, 2010 | 09:42 PM
corvettedaddy11's Avatar
corvettedaddy11
Nice box!!!
Old Aug 1, 2010 | 09:56 PM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Interesting. How does it play?
Old Aug 1, 2010 | 10:29 PM
Ashc2025's Avatar
Ashc2025
Not sure, just finished getting it in. The woofers need break in as well, I should be able to get it thumping by the end of the week. It's mainly MDF so I have high expectations
Old Aug 1, 2010 | 10:56 PM
paint-tech's Avatar
paint-tech
Looks good for your first try thats for sure. Did you calculate the cubic feet of air requirements for the speaker? It looks real small But pics are deciving. Anyway looks great
Old Aug 1, 2010 | 11:15 PM
Ashc2025's Avatar
Ashc2025
Originally Posted by paint-tech
Looks good for your first try thats for sure. Did you calculate the cubic feet of air requirements for the speaker? It looks real small But pics are deceiving. Anyway looks great
The case isn't tuned, but the woofers only require .5 square feet, and I did create a port to the dimensions required by the manufacture. It looks like the box holds more volume than that, so if it's to big I can fill some space with cotton or other filler..... I hope
Here's a shot of the internals:
Old Aug 1, 2010 | 11:21 PM
HowlinC5's Avatar
HowlinC5
I use cotton in the back/bottom of all of my enclosures as it seems to help "absorb" some of the notes you don't want to hear.
Old Aug 1, 2010 | 11:29 PM
jrose7004's Avatar
jrose7004
Nice job!
Old Aug 2, 2010 | 01:21 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by jrose7004
Nice job!
Old Aug 2, 2010 | 07:33 AM
Ashc2025's Avatar
Ashc2025
I hear tell fiberglass has some weird effects with bass notes, I might just have to go down that route. Still waiting on my stereo from Double DIN so only time will tell.
Old Feb 25, 2020 | 04:51 PM
Tourmax's Avatar
Tourmax
Well, its not perfect but its a good first attempt:
Even with the few small irregularities (that only I can probably see), its 100% better than that big, pointless foam pad (ie: breadbox) GM stuck in there.
It will work for this season. It is, however, a little bit on the heavy side. Its not “heavy” per se, just heavy for what it is.
Next winter I’ll probably yank it back out and make a fiberglass mold off it. Then I can reproduce it in fiberglass to save a little weight and fiberglass is also a bit easier to get smooth and straight as opposed to body fill over the 1/8” aluminum this one is made from.
No, I’m not “reproducing” it. Replicating it in fiberglass is only for my personal use. Not selling the original either, so please don’t ask. I threw up the pictures so others could see how to make their own (if they want to). I have no interest in making them for sale, either as a raw casting or a finished piece.
Old Feb 25, 2020 | 05:24 PM
knewblewkorvette's Avatar
knewblewkorvette
Old Feb 26, 2020 | 08:30 AM
dskinsler83's Avatar
dskinsler83
I would say yes post the step by step. Heck why not?!?
Old Feb 26, 2020 | 03:22 PM
Hitman227's Avatar
Hitman227
Great job!
Yes you only need the volume range the subs are rated for - many call for less than a cubic ft. per speaker..
Also concur with adding cotton to the inside of the box...will absorb some of the *loose* note ranges..
Originally Posted by knewblewkorvette
Lol
Old Feb 26, 2020 | 05:39 PM
knewblewkorvette
You do realize this is a 10 year old thread???
Old Feb 26, 2020 | 05:44 PM
dskinsler83
Damn it!!
Old Feb 26, 2020 | 07:55 PM
Hitman227's Avatar
Hitman227
I did not.
Old Feb 27, 2020 | 10:15 PM
Brackets's Avatar
Brackets
Originally Posted by dskinsler83
Damn it!!
To Custom subwoofer box
