High Temps = High Temps
Old Aug 2, 2010 | 10:13 PM
killain's Avatar
killain
Oldtimer
Originally Posted by AlexSmith
I'd like to believe that Chevrolet would have engineered the LS1 to be able to operate at this temp level without having to retune the factory settings.
-Alex
Well your more than likely right Alex. My 2003 runs about 210- to not quite 220 degrees even in these dog days of summer, with the A/C on and stop and go traffic. And lets face it, if it's not broke, don't fix it !
Old Aug 2, 2010 | 11:33 PM
BOHICA76's Avatar
BOHICA76
Mine never seems to go above the middle which is 220 I believe. Today was 108 degrees outside here in middle of kansas and my ac was on full blast.
Old Aug 3, 2010 | 12:26 AM
CatCam's Avatar
CatCam
This weekend I'm going to blow mine out with compressed air....
question: What kind of air adapter thingy do you use to get all up in there???? Pictures please!!
Thanks to everyone for your posts on this -- you are a wealth of knowledge!
Old Aug 3, 2010 | 01:02 PM
Jet-Jock's Avatar
Jet-Jock
This may help some...
http://forums.corvetteforum.com/c5-g...-radiator.html
Old Aug 7, 2010 | 03:16 AM
wcdaniel's Avatar
wcdaniel
Originally Posted by Jet-Jock
There is a procedure to burp the system.
Have you checked for debris between the radiator and condenser? Remove the cowl on top and inspect between them. You may have material build up. Compressed air and a lint brush from Home Depot works well. Never use a brush to go up and down on the fins, brush along the fins.
My wife thought we burped them like a bady !!!!!
Old Aug 7, 2010 | 11:16 AM
glorysends's Avatar
glorysends
I usually run around 220 but I have noticed since I put a front splitter on my temps go past it. Would that really make a difference?
Old Aug 8, 2010 | 03:03 PM
Z01POWERED's Avatar
Z01POWERED
3rd Gear
wow, just cleaned between the radiator and condenser didn't seem to be to dirty but my baby is running 10-15 degress cooler. was runnung 220-235 around town! that brush worked great Thanks:
Old Aug 9, 2010 | 11:53 PM
wcdaniel's Avatar
wcdaniel
Default Bottom-Feeder
First off I LOVE my 2003-C5. But, the C5 is truly a bottom-feeder. Thanks to the jerks that do now know how to mow their yards by sending the grass clippings onto the roads. A large mass of it had sucked up to the top of my radiator. My air compressor and about an hour of work cleared it all out. I can safely suggest my 'running-hot-in-traffic' problems are completely history !!!! Thanks for the info !!
Old Aug 10, 2010 | 01:13 PM
Dominic Toretto's Avatar
Dominic Toretto
I did not lift my car but I did take my washing brush to the radiator from under the car as best as possible and didn't notice any difference in temps. I didn't see much of any grass in there. Just some light dust. I don't know if an compressed air can will do much in my situation. I'll attempt to get the front off the ground this weekend and take a peak.
-Alex
Old Aug 10, 2010 | 07:09 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Standstill temps will also vary based on road surface. Asphalt tends to generate far more heat specifically from it's color, design and density compared to concrete. When sitting on concrete, the fans are sucking very hot air from the road surface of the which in the case of ashpalt can gete as high as 150 in the houston sun.
Old Aug 13, 2010 | 01:58 AM
wcdaniel's Avatar
wcdaniel
-Alex
Alex, I forgot to mention that I put mine up on ramps before I could get under there and do a proper inspection of the whole deal. Twice I thought there was no way more stuff could come out but I was wrong. Stuff just kept coming out.
Old Aug 13, 2010 | 10:07 AM
jedblanks's Avatar
jedblanks
I'm really really sorry for this, but:
That's what she said.
I just couldn't resist.
And I'll add that a new radiator is not too expensive and not to labor intensive, so if your car is 8+ years old, it might be worth the investment.
Old Aug 13, 2010 | 11:43 AM
  #33
Dominic Toretto
LMFAO!!
-Alex
Old Aug 13, 2010 | 07:50 PM
  #34
wcdaniel's Avatar
wcdaniel
As bon-Jovi said Shot to the heart !!!!! Well done. I left meself completely open for that one !!!!! wonderful page out of my playbook !!!!! :o:o
Old Aug 13, 2010 | 11:55 PM
  #35
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Originally Posted by brendan.9
i was running at 226 to 230 at 70mph with about 80 outside with the ac on
Now I would say that is too high, In 100 degree heat going 70 with the air on I run around 205
Old Aug 14, 2010 | 07:51 AM
  #36
Jet-Jock's Avatar
Jet-Jock
In our humidity and heat here in FL, at highway speeds daytime temps in the upper 90's I run between 196-198, AC on... pure stock. In the evening hours it settles to 196.
Old Aug 14, 2010 | 08:01 AM
  #37
retired cop's Avatar
retired cop
Well its hot in South Fla. I put in a 180 thermostat. My tuner has the fans come on at 200 degrees. Car never gets hotter than 207 degrees no matter what the conditions.
