High Temps = High Temps
Old Aug 2, 2010 | 05:08 PM
CatCam's Avatar
CatCam
Default High Temps = High Temps
Wow -
104 degrees outside today and the Vette was running warmer than usual. As I'm told by everyone on the Forum, not to worry, it still messes with me to see my coolant temp run up to 210 with the AC on when I'm at a standstill....it is worse if I turn off the AC because the electric fans don't run.....
It was so hot today my GY runflats actually felt soft!!
I always understood that heat was a killer for engines and components, I wonder why GM made the setpoint for the fan to kick on at 225 degrees? seems rather high....any work around for this?
Old Aug 2, 2010 | 05:10 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Have your tuner turn your fans on at a lower temp.
Old Aug 2, 2010 | 05:20 PM
C5XTASY's Avatar
C5XTASY
Old Aug 2, 2010 | 05:25 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I assume the OP was running his A/C - and if he was both of the fans were already running at high speed....changing the setting of when the fans come on will not matter if they are already running.
210 degrees idling in traffic is not that hot - and certainly wouldn't be a cause for concern to me.
Old Aug 2, 2010 | 05:45 PM
sneakelman's Avatar
sneakelman
Black. I was referring to the statement he made about when he had the AC off, his temps were higher.
I shoulda specified more clearly.
Old Aug 2, 2010 | 05:49 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
As stated above you could have your tuner set the fans to come on earlier instead of so late -
You can also get a 180* thermostat that will compliment the new fan settings and if you really want the temps down you can get a Electric water Pump too works at full potential even at a stop light 55 GPM
Thanks,Matt
Old Aug 2, 2010 | 06:05 PM
Dominic Toretto's Avatar
Dominic Toretto
I was going through stop and go traffic here in DFW and saw my water temp spike to 228F!!! This was with the AC blowing. I turned the temp from 60F to 90F upon moving and it "cooled" the water temp down to 220F. And not to mention I had a radiator flush a few weeks ago. It's hard to imagine that only a few degrees difference in the air makes this large a difference. For engines to normally operate at double the ambient temps I just don't understand how a few degrees difference in the air makes the water temp get so much warmer. It's almost like you have to modify the stock cooling system to feel safe.
-Alex
Old Aug 2, 2010 | 06:08 PM
jrose7004's Avatar
jrose7004
When it's 104 outside you've got to expect your operating temps to go up.
Old Aug 2, 2010 | 06:16 PM
Chicago1's Avatar
Chicago1
Sounds better then what people normally run around here,so what was the complaint again?!
Old Aug 2, 2010 | 06:24 PM
CatCam's Avatar
CatCam
HaHa - New Mexico! I guess our heat is mearly child's play to you guys out there!
Old Aug 2, 2010 | 06:47 PM
brendan.9's Avatar
brendan.9
i was running at 226 to 230 at 70mph with about 80 outside with the ac on
Old Aug 2, 2010 | 07:19 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Made a run to Lake Charles yesterday to make my regular donations to the boats. On the way back started hitting 220 with a/c on,when it started creeping up to around 235 I turned a/c off. After that it started going down,and I made sure to try to stay clear of traffic so I could get more air into my car. It didn't get as low as I would like, but it did get down to 220, and it was HOT out on the road. Hopefully it's just this heat we're going through right now, but I'm definitely keeping an eye on it.
Old Aug 2, 2010 | 07:25 PM
Chicago1's Avatar
Chicago1
It's brutal in some spots out here!!!
Here is some info for you guys from the manual
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
When you have "cooling problems" always check the radiator for foreign material (grass, leaves, plastic bags, etc.), since these C5s are bottom breathers, they act as road vacuum cleaners.
Old Aug 2, 2010 | 07:32 PM
had2have-it's Avatar
had2have-it
Seeing 225+ deg in slow moving traffic. New Orleans was 99 today. When I'm out of traffic and can move at 65-75mph it will drop to 190. Try to avoid traffic and have low mile proper coolant along with a fresh oil change. I also reframe from driving it hard at an elevated temp
Old Aug 2, 2010 | 07:43 PM
killain's Avatar
killain
Oldtimer
I've often wondered why any of you who live in Texas or anywhere along the Gulf coast, don't have a tuner reset the fans to come on a little earlier and put in a 160 degree thermostat. But this has been a really odd summer. We usually have 24 days above 90 degrees, but it's only August, the Maple tree out front is sending off seedling and we closing in 35 days of 90 degrees plus. I can only imagine what you folks down south are having to deal with. It's the humidity !
Old Aug 2, 2010 | 07:53 PM
Dominic Toretto
Originally Posted by killain
I've often wondered why any of you who live in Texas or anywhere along the Gulf coast, don't have a tuner reset the fans to come on a little earlier and put in a 160 gegree thermostat.
I'd like to believe that Chevrolet would have engineered the LS1 to be able to operate at this temp level without having to retune the factory settings.
-Alex
Old Aug 2, 2010 | 08:46 PM
gto442w30's Avatar
gto442w30
I was having some cooling problems like you are describing. Today I jacked up the front everything looked clean. While it was up I blew it out with my air compressor and you would not belive all of the dirt & grass that came out. Went out for a test drive this afternoon in the hotest part of day (105 heat index) and ran a whole lot cooler!
To High Temps = High Temps
Old Aug 2, 2010 | 08:58 PM
Blew by you's Avatar
Blew by you
I did the same thing with the air compressor, and it dropped me from 220's to 190's in the same outside temperatures, same city driving conditions. The radiator can look clean but blow it out you will be surprised how much may come out!.
Old Aug 2, 2010 | 09:26 PM
brendan.9's Avatar
brendan.9
that sounds like a good idea gonna do that before the next time i go out! i took the cap off and burped it ran a bit cooler than once i shut it off than started it back up after it washed it went back to the same temperature as before.
Old Aug 2, 2010 | 10:03 PM
Jet-Jock's Avatar
Jet-Jock
There is a procedure to burp the system.
Have you checked for debris between the radiator and condenser? Remove the cowl on top and inspect between them. You may have material build up. Compressed air and a lint brush from Home Depot works well. Never use a brush to go up and down on the fins, brush along the fins.
