keyless entry
Old Aug 2, 2010 | 05:09 PM
prestige6's Avatar
prestige6
Default keyless entry
Both of my remotes stopped working.. Put new batteries in both remotes,they still don't work.Can someone tell me how to program and what to do. I have C1 and C2's this is new to me... Thanks
Old Aug 2, 2010 | 05:12 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Re-train them. Take the first one, hold down the lock and unlock buttons until the horn chirps, then do the second one.
Old Aug 2, 2010 | 05:18 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Old Aug 2, 2010 | 09:47 PM
prestige6's Avatar
prestige6
Default remotes
That worked but why did it lose the programing????
Old Aug 3, 2010 | 07:41 AM
Try reprogramming them by going through the DIC menu - the procedure is in your owner's manual. If you don't have a manual, you can download one for free from www.gmpartshouse.com.
If that doesn't work - either you have two bad fobs or the receiver in the car is not working properly.
Old Aug 3, 2010 | 02:34 PM
markKlein's Avatar
markKlein
Did you do something where you disconnected the car battery? That could do it.
Old Aug 3, 2010 | 07:53 PM
sneakelman's Avatar
sneakelman
Because you took the batteries out. The fobs don't hold memory without the batteries in. The car didn't lose the programming, your fob did. If the car loses the programming, you'll have to go through the DIC(like Jack stated above) to re-program the fobs to the car.
Also, if you unhook your battery on the car for any length of time you will have to re-train te fobs, and re-set your settings.
Old Aug 4, 2010 | 08:56 AM
markKlein's Avatar
markKlein
That is not correct, unhooking the battery in the car briefly will cause the car and fob to lose "sync". They can normally be resynched using the lock/unlock buttons. If the battery is disconnected for an extended period of time you wil have to fully reprogram.
To keyless entry
