ABS Module
C5 besides the dealer? I can find only for 01 and up. Looked up at absfixer and they cant rebuild or carry any for my yr.
Take the part number off the top of the module itself and do a search on it. GM does not make them anymore -
I can't remember if they have a replacement for them or not, call the parts counter at GM and inquire with your year specific ABS moule and they will let you know
If it's outback, then it is the early in the year model module!
If it is located in the front by the power steering unit then it is a late in the year model module, with active handling.
Thanks,Matt
Been looking thru the forum here and seen that lots of Vette fans have this problem. Since I've had this TRAC display on since I bought it 2yrs ago I think maybe it's time to have it replaced.
Any ideas?
Any ideas?
It is not unusual for the lights to come on if driving aggressively, although they should clear when the car is restarted. Get the codes from your DIC and post them..
Any ideas?
Pull the codes first then try the suggestion below
It sounds like you have a late model unit with the Active Handling, you could try to pull the handle down on the ABS unit to remove the clip going into the module, get some contact cleaner and clean off the female and male part of the connector.
I had this problem, the female part of the clip/harness was worn or pushed up and I had to take a dental pick set and re-shape the prong to make a better connection on the male part.
The handle on the ABS unit will allow you to unclip it, simply pull it up and it'll pop out of the module.
You can also pull the two fuses going to the ABS unit in the Battery Den area, unscrew the the fuse panel top and there will be under the lid the diagram for the fuses, these are the MAXI (Large Fuses) pull the 20 AMP fuse and check it (I had one blown, and it kept making the light come on due to NO COMMUNICATION), and pull the 40 AMP and check it too.
I'd pull the fuses first and check them and leave them out when you use the contact cleaner, then reinstall the clip and then reinstall the MAXI fuses in their proper places and hopefully that will get you off into the right diretion.
Let me know how it goes, even if you have the ABS unit in the rear this will work the same
Thanks,Matt
RFA-C2100 & C2115
After doing a bit more research its LF & LR TPM Sensor Malfunction....Is this correct?
So what do I need to do now?
I also found many "H" codes. Are these ok the clear or should I just leave them?
It does sound like what I had happen to mine with the loss of communication and or power. Follow what I did in the post and see where that gets you.
Thanks,Matt
