Help!! ABS wheel speed sensor
Old Aug 3, 2010 | 04:53 PM
JohnnyQ's Z06's Avatar
JohnnyQ's Z06
Default Help!! ABS wheel speed sensor
I need helping finding one of these. Think its called the ABS wheel speed sensor.
Old Aug 3, 2010 | 08:04 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The ABS speed sensor is an integral part of the hub/bearing assembly. Not an easy swap out and the assembly is rather expensive. What you are showing is the pig tail lead that connects the sensor to the car wiring harness. Normally they are permanently attached to the sensor and are not individually replacable. You might check and see if you can solder and properly insulate the wires back to the sensor. It depends on where they were broken off an if you have enough wire exposed to make the splice. Otherwise you are into a hub replacement.
If the wires and connector coming out of the hub are OK and you need the connecting harness, contact Gene Culley - GM Parts - forum vendor for best price.
Old Aug 3, 2010 | 08:57 PM
Toms02C5's Avatar
Toms02C5
Gene will have the best price around...
Old Aug 3, 2010 | 09:04 PM
JohnnyQ's Z06
Thanks guys
Old Aug 3, 2010 | 09:14 PM
Jet-Jock's Avatar
Jet-Jock
This will help:
Gene's GM Parts House Monthly parts special:
http://forums.corvetteforum.com/c5-g...rts-house.html
484.949.2099.
Old Aug 4, 2010 | 05:31 AM
I agree with giving Gene at gmpartshouse a call. Or you can check prices with Bob at Fichtner Chevy.
Old Aug 4, 2010 | 03:13 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Both long term Forum Vendors and great people to work with.
To Help!! ABS wheel speed sensor
