Traction control?
Old Aug 4, 2010 | 10:06 AM
brendan.9's Avatar
brendan.9
Default Traction control?
When i shut off my traction control i can't do a standing burnout w/o water. but once i put it in competitive handling it will go but than i can spin it around the corner cause the active handling comes on. whats the difference between the two?
Old Aug 4, 2010 | 10:27 AM
MNR's Avatar
MNR
Traction Control off is everything off (including active handling)
Competitive Driving is traction off but active handling still on
Old Aug 4, 2010 | 10:38 AM
brendan.9's Avatar
brendan.9
ok but why can i do a standing burnout way easier with competitive driving than traction control off?
Old Aug 4, 2010 | 10:42 AM
steve8's Avatar
steve8
There should not be any difference.
Old Aug 4, 2010 | 10:57 AM
MNR's Avatar
MNR
There shouldnt be a difference....
Old Aug 4, 2010 | 11:33 AM
imavettegirl's Avatar
imavettegirl
standing burnouts are very hard on the car.
what is the purpose of them to you?
Old Aug 4, 2010 | 11:55 AM
Z06Electron's Avatar
Z06Electron
Ask me what breaks when you get the idea to do 360 burnouts in your car.
Not my Corvette, but I learned the hard way in my Firebird
Old Aug 4, 2010 | 01:00 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Active handling - employs yaw sensors and if a situation is detected that the vehicle is about to swap ends, it applies brake in the opposite corner to control a spin.
Traction control will retard timing it it detects the back wheels are spinning faster than the fronts.
Competitive driving shuts off traction control and leaves active handling engaged.
If both traction control and active handling are turned off - you are on your own to control the vehicle.
So as you can see - having everything turned off or putting the car into Competitive Driving mode should be exactly the same. As to why it won't burn the tires with everything turned off - no idea.....
Old Aug 4, 2010 | 05:08 PM
MNR's Avatar
MNR
Just a thought, how new are your tires? And is your car stock?
Old Aug 4, 2010 | 05:53 PM
paint-tech's Avatar
paint-tech
If you have a 2:73 gear It is hard to spin tires with out line lock. Throw a 3:42 and a stall in there and you will be buying new tires in no time.
Old Aug 4, 2010 | 07:09 PM
brendan.9's Avatar
brendan.9
Yea its stock ^^ what would that cost? i hate the low end of the car until it hits like 30
Old Aug 4, 2010 | 07:12 PM
brendan.9's Avatar
brendan.9
tires are about 50-60% not new but not bald like my buddy's stang
Old Aug 4, 2010 | 11:30 PM
MNR's Avatar
MNR
Does it have 2.73's (A4)? It is pretty hard to spin from a stop with those gears.
Old Aug 4, 2010 | 11:54 PM
brendan.9's Avatar
brendan.9
yeah i realized that but wanna change them how long does it take to change them?
Old Aug 5, 2010 | 12:48 AM
C5XTASY's Avatar
C5XTASY
and so the mods begin... Throw a set of 3.73s and a Yank SS3200 stall in that thing and don't look back.
Ed
Old Aug 5, 2010 | 01:51 AM
moserbe's Avatar
moserbe
I went with the Z06 carrier and 3.42 gears and a tune to adjust the shift points. BIG difference.
Old Aug 5, 2010 | 02:37 AM
Z06Electron
Or you could just swap over to something manly like an M6.
To Traction control?
