Scratch repair question...
Old Aug 5, 2010 | 08:29 PM
LaMagred02's Avatar
LaMagred02
Default Scratch repair question...
Ok...so about a month or so ago I had about an 8 inch scratch repaired right in front of the passenger side rear wheel. The scratch was deep as I had caught a concrete turnstile at the bank drive thru. Anyway, a few days ago I noticed that about an inch of the scratch was again visible so I went back to the repair shop and was told that something obviously had struck the car and that this was new damage. I said that it was exactly the same scratch and that they should repair it at no charge. I got nowhere, so I am going to speak to the owner on Monday.
Any thoughts on how I can prove this was not new damage?
Thanks .
Old Aug 5, 2010 | 08:36 PM
The chances that new damage happened in exactly the same spot are very slim IMO. If you have pics of the original scratch, that would help. Otherwise, you may just have to rely on the owner to come through for you. Good luck.
Old Aug 5, 2010 | 08:39 PM
LaMagred02's Avatar
LaMagred02
The chances that new damage happened in exactly the same spot are very slim IMO..
that is exactly what I said.....
Old Aug 5, 2010 | 08:50 PM
Wt99C5's Avatar
Wt99C5
Did you happen to take pictures after the original repair, it might prove they missed a portion of the scratch.
Old Aug 5, 2010 | 08:53 PM
LaMagred02's Avatar
LaMagred02
no pics...the repair looked perfect a month ago....
Old Aug 5, 2010 | 08:57 PM
Wt99C5's Avatar
Wt99C5
Is it possible the material they used to make the repair "shrunk" ?
I know bondo can shrink/ crack.
Old Aug 5, 2010 | 09:00 PM
LaMagred02's Avatar
LaMagred02
I don't know.....I am looking for possibilities to bring up with the owner....thanks
Old Aug 5, 2010 | 09:13 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Did you go to the bank again?
Old Aug 5, 2010 | 09:29 PM
LaMagred02's Avatar
LaMagred02
yes....but carefully
Old Aug 5, 2010 | 09:36 PM
jrose7004's Avatar
jrose7004
That was my thought!
Old Aug 5, 2010 | 11:28 PM
dmarkshark's Avatar
dmarkshark
I find it hard that you would not have noticed it in the first place. I know I would have carefully looked at it down the side to see that they did a good job, and if it looked like a good job I doubt they would miss a 1 inch section. I doubt that there was anything that would shrink in a scratch repair, unless they did a really crappy job and just filled it in, smoothed it out and painted it. Does it look like the paint has cracked open or a real scratch?
Old Aug 6, 2010 | 09:22 AM
LaMagred02's Avatar
LaMagred02
It does look cracked open...it is part of the original scratch in my opinion....
Old Aug 6, 2010 | 10:35 AM
dmarkshark's Avatar
dmarkshark
If it looks cracked open, and they had definately painted it, then I think they need to fix it and correct their bad job. Good luck. Let us know how this plays out.
Old Aug 6, 2010 | 10:39 AM
dougbfresh's Avatar
dougbfresh
What did they touchup, colorcoat. clear BOTH? A lot of the "touchup" paint is not the same paint the factory uses-the colors can get close but they weather different, especially lacquers. The scratch repair can shrink and show through the repair, crack repair can be even more visible over time as the repair materials shrink.
Old Aug 6, 2010 | 12:33 PM
dmarkshark's Avatar
dmarkshark
Not in 4 weeks time? Should not happen.
Old Aug 6, 2010 | 08:16 PM
robsc501's Avatar
robsc501
Hi There,
Most reliable shops guarantee their work for as long as you own the car or truck.
robsc501
Old Aug 8, 2010 | 10:42 AM
LaMagred02's Avatar
LaMagred02
Originally Posted by robsc501
Hi There,
robsc501
I will tell them that...
To Scratch repair question...
Old Aug 9, 2010 | 05:27 PM
LaMagred02's Avatar
LaMagred02
The owner said it is new damage and will not honor his warranty and fix the scratch. I have filed a complaint with the BBB.
Old Aug 9, 2010 | 05:34 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Something's not right. Scratch in same area? Doesn't make sense as you and others have already determined.
Did you file an insurance claim. If so the insurance adjuster has pics of the damage.
Did the body shop take pics? Many do now as a way to confirm and document work.
Post your question in the Car Care Forum. Those guys are experts in car care and may have an idea for you.
Good luck and keep us posted.
Old Aug 9, 2010 | 05:40 PM
LaMagred02's Avatar
LaMagred02
My ded is $500 so no ins claim...
If the shop took pics, they did not inform me.
Thanks for your suggestions.
