C-5 Question
Old Aug 6, 2010 | 04:02 PM
ffas23's Avatar
ffas23
Default C-5 Question
Being a C-2 and C-3 Corvette owner for years I have to admit I don't know much about C-5's. Right now I am in the market for one though, Bone Stock, with low miles. Automatic preferred being my wife would like to drive it but stick would also be considered being both my C-2 and C-3 have a 4spd manual trans.
Might be a stupid question but I see many C-5's for sale with body side moldings. Have to admit based on pictures I have seen I really don't care for the look of side molding on the C-5. Does anyone know if they are removable without messing up the paint on the body? In other words is it 3m tape that holds them on or are they mounted with some sort of body clips? If I know they can be removed with out doing damage it would open up more C-5's for me to take a look at.
Old Aug 6, 2010 | 04:18 PM
dougbfresh's Avatar
dougbfresh
The are easily removed with fishing line-do a search here, there are MANY posts. The risk you run is if the car has even been repainted and they taped around the moldings you have a real problem then.
Old Aug 6, 2010 | 04:26 PM
PostShawn's Avatar
PostShawn
Many cars don't have them. Don't let a car having them be the reason for not buying them. Heck, you can remove them easily and sell them too for a little extra cash, although they don't usually fetch all that much money.
Old Aug 6, 2010 | 04:47 PM
HowlinC5's Avatar
HowlinC5
Mine didn't come with them. And you are right, they do look better without them.
Old Aug 6, 2010 | 04:48 PM
03WhiteConv's Avatar
03WhiteConv
Dings look better on the strake than the door skin...
Old Aug 6, 2010 | 04:53 PM
jrose7004's Avatar
jrose7004
Yep, they can come off.
Old Aug 6, 2010 | 05:04 PM
cammedvette's Avatar
cammedvette
Mine had them.... pulled them off no problem.. Parked it outside on a hot day and ran a piece of fishing line under them and they came right off. Cleaned up the residue from the tape with some Goo Gone and she looks really good... Se for yourself!!
Old Aug 6, 2010 | 05:12 PM
JPM's Avatar
JPM
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
If you do remove them...play it safe as many c5s have been repainted at one time or another and body shops usually paint the panels with the side moldings on the car. This will cause a paint buildup around the side molding if they are removed.
My suggestion is to remove the small molding in the front first to see if there has been any paint work done to the vehicle.
Old Aug 6, 2010 | 05:40 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Yep....ez to remove (although I kept mine for added protection....don't mind them at all) with some nylon/fish line and a hairdryer.
BTW being new to the C5 you may want to take a look at the C5 Sticky at the top. TONS of great useful information.
Old Aug 6, 2010 | 05:44 PM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
easy to remove but I like them...it's all a matter of what looks good to you...
Old Aug 6, 2010 | 10:30 PM
97Cruzr's Avatar
97Cruzr
8th Gear
removed mine a few weeks ago, can't tell anything was ever there. The tip about starting with one of the small moldings on fender first, was helpful. One observation, there were different adhesives used on each side of the car. One was black, the other gray. Gray was harder to cut through, but there was hardly any residue to clean up afterwards.
Old Aug 7, 2010 | 04:44 PM
ffas23's Avatar
ffas23
Thanks for the great response. I am going to take a look at a C-5 Coupe on Sunday without the side moldings. If I like the car I plan on taking it home with me on my car trailer. Thanks again for the heads up to my question.
Old Aug 7, 2010 | 10:27 PM
Easily removed like mentioned above, but there is a chance that the paint under the molding will be a slightly different shade than the rest of the panels due to fading.
Old Aug 7, 2010 | 11:57 PM
C5FORFUN2's Avatar
C5FORFUN2
Having them was one of the requirements when looking for mine. To me it adds a nice edge to a dull side.
To C-5 Question
