A fool's errand . . .
Old Aug 10, 2010 | 10:16 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by Toque
When I first found my battery was slipping around I tightened up the bracket, but the battery still moved if i shoved it hard enough. That was not good enough for me.
I just went to Home Depot, and got some of the 3M Double sided foam sticky tape. I lifted the battery, and placed the double sided sticky tape on all the contact points that the battery sits on (around the bottom edges of the battery). Then placed the battery down on top of the sticky tape, and tightened down the bracket. It will not move at all now.
I got the stuff at Home Depot. Its grey, but has red backing on it that you peel off. The stuff I got was about an inch wide.
Hope this helps.
Toque
Thanks! Do you think Home Depot also sells the Black/Red Z06 door panels?! I think they would look just as great on MSG as they do on silver!
Old Aug 11, 2010 | 04:26 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Not sure.. It can't hurt to try...
