A fool's errand . . .
Put in these (oem to show size difference)
[IMG]
[/IMG][IMG]
[/IMG]And these
[IMG]
[/IMG]Aside from a little glitch with getting the top bolt on one of the rear sway bar brackets to seat all the way back into the hole we had just taken it out of, all went together swimmingly. While pulling out the old stuff, the plastic end links were not really in bad shape, but the metal ones will surely banish my "clunk" for good. Everything else is in great shape, bushings, ball joints, nice tight suspension, cant budge anything....rock steady
All is well, clean it up, back it out onto the street, go to corner, sitting a little high but that will settle down, right onto sidestreet, lets test this baby
....do a little slow speed slalom...."clunk"
WTF?
Back to garage, grab mechanic friend that helped me do the install in pass seat, back out...."clunk"Back to garage, up on lift, check everything.....really...everything. Front end is rock steady, no play anywhere, tie rods, steering rack....really clutching at straws now.
Light bulb goes off in my head.
"Put it back down", open hood, check battery tie down, nope....thats tight. Push on battery....."clunk"
.....two very happy guys
. Recently put a new battery in (Die Hard Platinum), but have since found out that they gave me the wrong battery for the car (its what their book says a C5 takes, and its correct except for the Reserve Capacity...which is 90 and should be 120...but....its also a bit smaller than the correct one). I knew I tightened it down well when I installed it, but I didnt try to slide it left and right, I tried it front and back and it didnt move. Even with the hold down tightened until its touching the tray, it still slides side to side. I'll be getting the correct battery from them this week.
Doing shocks, sways and endlinks to stop a clunk unnecessarily...$540
Finishing the job to find you havent solved your original problem, then finding you also have the wrong battery in the car . . .well, not so good.
Later finding that your "clunk" was never really the "clunk" you thought it was, and that it is easily fixable at (probably) no cost . . .priceless
Does the battery label tell me the reserve capacity? Does the AC Delco also supposed to have a 120 reserve capacity? I assume the larger reserve capacity means a wider base/larger battery that does not slide around?
Also, nice Michelins.
The ride and handling have to be so much better now. I had my shocks replaced around 45,000 and I have 58,000+. That new sway bar is a lot beefier for sure.
Russ Kemp
I put some 3M double sided foam sticky taps under the battery, and tightened it down. Its FIRM in there now. The battery sits on a smooth plastic plate.
I'm not surprised more folks don't have this issue...
http://forums.corvetteforum.com/c5-t...ock-sound.html
Glad you figured it out !
Toque
Toque
I just went to Home Depot, and got some of the 3M Double sided foam sticky tape. I lifted the battery, and placed the double sided sticky tape on all the contact points that the battery sits on (around the bottom edges of the battery). Then placed the battery down on top of the sticky tape, and tightened down the bracket. It will not move at all now.
I got the stuff at Home Depot. Its grey, but has red backing on it that you peel off. The stuff I got was about an inch wide.
Hope this helps.
Toque
I'm using AC Delco 78-6YR/7YR Pro Series. Must have 120 reserve capacity.
http://vettetube.com/view_video.php?...25f49408d959ca
Thats "C4C5Specialist" (Paul) up there, he is a world class certified corvette guy and when he starts talking I usually listen
. The video is a bit long but it does explain why some problems (TC/AH Dic codes, Colum Lock issues etc) happen, they are often related to battery/electrical system maintenance.The item you mentioned (Reserve Capacity) is particularly important in the C5, he said you should look to have a battery with at least a 120 RC. There are other parameters (CCA Cold Cranking Amps and such) that you also need to look for (sorry I dont have the recommended number on that for you, but Im sure the one I have exceedes it).
I bought the Die Hard Platinum before I saw his video, when they checked their computer it showed this battery for a C5 Corvette, which is the one I installed:
[IMG]
[/IMG]As you can see, its a bit smaller than the tray area
[IMG]
[/IMG]and had room to slide towards the engine
[IMG]
[/IMG]If it met the requirements Paul outlined in the video, I would have just kept it and solved my "clunk" problem with a battery mat or something, but since I later found that I really should have a different model, I went ahead and swapped the one I bought in April for this one
[IMG]
[/IMG]Which we can see has enough RC and is the proper size for the tray
[IMG]
[/IMG]One reason I chose the Die Hard was the warranty and easy access to Sears from where ever. I bought the first one back in April, when I went back today and discussed it with them they just swapped out the old one for the new one and started a new warranty period from today
but its on the tread and should be easily repairable, will get to that this week also.Not really
but I do notice its a lot more stable on the cloverleafs and the bump steer I used to get at the railroad crossing enroute to the highway pretty much wasnt there the last two times I went by there.
From what Ive seen so far, the ride is worlds better, better when taking it easey (shocks better) and better when pusing it a little, I didnt think I had much body roll before but I can tell ya I definitly feel a difference now. Absolutely not too stiff.
I can see this is going to require extended testing . . . .alone in the car . . .closer to the edge of the envelope.....As soon as I finish some stuff I'm hip deep into around here . . ..I'll get right on that
Need more "vette" time
Best advise right here
