Speed signal input
Old Aug 16, 2010 | 04:08 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by Darksythe
Really? So just putting that wire to a ground somewhere in the car would work?
actually it involves moving the yellow harness wire over one spot in the connector AND THEN grounding it (yellow lead) and the green e brake wire to bypass the in motion lock out. if you haven't been on avic411.com you should check it out.
Old Aug 16, 2010 | 04:33 PM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Well I was going to bypass it originally but I had recently heard that even WITH the bypass, the GPS will shut the "bypassed" functions at a 10 or 20 MPH mark anyway. So I had decided not to bypass it if it just was going to shut down at 10 mph anyway. My info could be wrong though.
Mine performs all functions at any speed.
Old Aug 16, 2010 | 04:38 PM
Darksythe's Avatar
Darksythe
Good advice, Ill think about doing the "bypass" if yours works just fine blue. Lets hope I dont mess up moving that wire over haha.
And yea that z120 upgrade will be sweet. Hope the price gets lowered soon
Old Aug 16, 2010 | 05:45 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
its pretty simple
http://www.youtube.com/watch?v=N7H0iJoEGNo
Old Aug 16, 2010 | 11:34 PM
Darksythe's Avatar
Darksythe
Bleh! I just hooked everything up, works fine other than NO BASS. The WHOLE reason I went through the trouble of getting the adapter harness (XSVI-2004). The little silver box has an power led which is not lit. Why would this thing not be turning on? All the wires are correct as far as I can tell and I turned on the acc for 30 secs then turned it off like it said. I did have the radio connected at the time do I have to do the 30 second thing without the radio plugged in?
Old Aug 16, 2010 | 11:37 PM
0Double D Mods
Former Vendor
I am not a fan of that harness. The roem-vet1 is so much better and 40.00 less
however
did you connect the blue white wire from the radio to the blue wire in the harness? The blue wire will be the power antenna wire. If not this is your problem. Most people hook blue to blue and blue white to blue white. This is not correct
Old Aug 16, 2010 | 11:40 PM
Darksythe's Avatar
Darksythe
however
AHHHHHHHHHHHHHHHH thats what it is ty sooooo much Dennis! <3
Old Aug 16, 2010 | 11:58 PM
Darksythe's Avatar
Darksythe
The only wire have unhooked from the radio is a blue wire labeled Antenna control and on the harness the blue/white wire labeled amplifier turn on. I have NO blue /white wire coming from the radio. So really my only option is the blue to blue/white correct?
Old Aug 16, 2010 | 11:59 PM
0Double D Mods
Former Vendor
check and see if the blue white is on a harness with the rcs ends on it. I think your radio has it seperate
Old Aug 17, 2010 | 12:07 AM
Darksythe's Avatar
Darksythe
hmmm ok you are right , So how do I get the lead running to the big amp for the subs? Do I make the wire go to the harness amp and tap into it for the amp I have connected to 12' subs?
Old Aug 17, 2010 | 12:10 AM
0Double D Mods
Former Vendor
so you have subs with an amp and the factory speakers?
sorry just need to know exactly what your running
Old Aug 17, 2010 | 12:13 AM
Darksythe's Avatar
Darksythe
Yes sir. I have an amp in the back hooked up to a 12' sub and the factory bose speakers.
Old Aug 17, 2010 | 12:31 AM
  #33
0Double D Mods
Former Vendor
take the amp turn on wire and the blue wire in the harness and conenct to the blue white on radio harness
Old Aug 17, 2010 | 12:34 AM
  #34
Darksythe's Avatar
Darksythe
That sounds like the solution! If I have anymore problems would it be ok if I toss you a PM? I seemed to be quite plagued with them You have the patience of a saint
Old Aug 17, 2010 | 12:37 AM
  #35
0Double D Mods
Former Vendor
lol i am just setting here working on my website so might as well answer quesitons for a little while longer
yea or email me
dennis@doubledmods.com
or call me
shop 608 568 3011
cell 608 778 1851
Old Aug 17, 2010 | 12:40 AM
  #36
Darksythe's Avatar
Darksythe
[QUOTE=c5 BearsFan;1575033792]lol i am just setting here working on my website so might as well answer quesitons for a little while longer
Will do , Ima give it a go in a few mins. Ill post back with the results
Old Aug 17, 2010 | 12:44 AM
  #37
0Double D Mods
Former Vendor
[quote=Darksythe;1575033803]
ok will set tight and see
Old Aug 17, 2010 | 12:50 AM
  #38
Darksythe's Avatar
Darksythe
yea or email me
or call me
shop 608 568 3011
cell 608 778 1851
I might drop you a line tomorrow if your not too busy, seems that it still isnt working. I know it is something simple. Since its so late Ima get some rest so Ill be more refreshed attempting this lol.
Old Aug 17, 2010 | 12:53 AM
  #39
0Double D Mods
Former Vendor
ok just call me
